It is currently Wed Jul 30, 2025 8:58 pm
 Post subject: Flat Spot Issues
PostPosted: Tue Aug 09, 2005 6:30 pm
I have yet another problem with the mini. I have a really bad flat spot when i take off. My other half has checked the timing, replaced coil, leads, plugs, points and distributor cap and rotor. He took the carby off his K and swapped it, which made the fuel usage really good, but i still have the flatspot. He put new oil in the carby, and took that spacer out with the pipe end thing on it in case that was the problem... still the same. He even put the vacuum advance distributor out of his K into the mini.... boy is his car starting to miss parts now...lol
Anyway, ideas would be good.
Thanks.
1978 Leyland Mini 998LS All Original *Sally*
2002 Mini Cooper *Coopa*
PostPosted: Tue Aug 09, 2005 7:40 pm
What air filter... stock or a sports one? Makes a big difference... :wink:
PostPosted: Tue Aug 09, 2005 7:50 pm
I think its just a stock one..doesnt look fancy or anything :oops:
PostPosted: Tue Aug 09, 2005 7:56 pm
Screw the main jet adjusting nut right up with your fingers. Then undo it 12 flats (2 turns). That's a basic starting point for mixture adjustment.
It may be screwed up too much now (too lean).
PostPosted: Tue Aug 09, 2005 8:10 pm
OK will try that tommorrow and see if he runs with no flat spot....
 Post subject: Two carbies lean??
PostPosted: Tue Aug 09, 2005 8:30 pm
Doc..."He took the carby off his K and swapped it, which made the fuel usage really good, but i still have the flatspot".....whats the chances of both carbs being set to run lean??? Maybe a fuel delivery problem :?:
PostPosted: Tue Aug 09, 2005 8:31 pm
Maybe.. but let's check it first before moving up the fuel chain... :wink:
PostPosted: Tue Aug 09, 2005 8:46 pm
I will try Docs idea and let you know if the car is still being a mongrel...
Users browsing this forum: drmini in aust and 76 guests
