It is currently Sat Jul 19, 2025 11:52 am
 Post subject: Coolant level
PostPosted: Thu Aug 04, 2005 9:38 am
In the 2 Mini's that I have, the coolant level sits about 1 inch below the very top of the radiator neck.
If I fill it to the top, and run the motor, it will 'overflow' (with cap on) till it reaches this level.
Is that right?
On another note, if I fit an overflow bottle, with coolant return to the radiator, do I need a different radiator cap? And does the position height of the overflow bottle have any effect on it's abillity to return coolant to the rad?
 Post subject: Re: Coolant level
PostPosted: Thu Aug 04, 2005 11:34 am
Is that right?
iv had the same problem with my radiator level and it overflowing,iv been told to keep it at about an inch below full,seems to work out fine. :P
PostPosted: Thu Aug 04, 2005 11:36 am
hrmm, are you sure you have the right cap Anton? there are 2 types, one has a longer neck.
I keep mine just level with the top of the radiator gills and it doesn't overflow...
I am pretty sure that the overflow system is a pressurised system and uses a different cap, but I could be wrong :? :oops:
Lillee - 1969 Morris Mini K
PostPosted: Thu Aug 04, 2005 11:49 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
it is normal anton every mini i have ever owed dose it
makka
PostPosted: Thu Aug 04, 2005 11:50 am
makka
thought so :mrgreen: thanx makka
PostPosted: Thu Aug 04, 2005 12:03 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
no worries mate gee i'm being helpful today .... i will have to spam some threads to make me feel better
makka
PostPosted: Thu Aug 04, 2005 12:11 pm
I fitted an overflow to mine Anton, coz I wanted to avoid having to top the radiator up all the time coz it would spit some out every time you stop basically, gradually needing constant replacing just because the engine heats up, water expands, pushes a bit out and loses some to evaporation from the hot radiator and engine.
The overflow works great, yes you do need a different cap and if the throat of your radiator isnt the right one I dont think you can do it. I got my radiator professionally cleaned and they replaced the top neck and cap housing coz they didnt have a cap that would fit properly :roll: I mounted the overflow tank just behind the grill next to the radiator and seems to be working perfectly :)
Repco sells them for $19 or $25, white plastic, match the replacement washer tank/motor tank also.
Edit: my overflow tank
www.crazybitchracing.com
PostPosted: Thu Aug 04, 2005 12:20 pm
yea I got a overflow tank from a Hyundai Excel...small and nicely shaped. I was thinking about the exact same spot you mounted yours.
My rad has been redone by Natrad, and it looks like they have replaced the neck....it's been soldered on and is slightly crooked :lol:
What is the visible difference between the necks then?
PostPosted: Thu Aug 04, 2005 12:29 pm
Im not sure, Id guess the overflow exit point must be positioned so that fluid can get back in when required. Between two flanges/seals in the special caps?
One seal would stop water getting out the top radiator cap, but the lower seal would aloow water into overflow tank and back in?
I didnt have a really close look it it, was going to, but then thought :) its working, who cares how :)
edit: Closeup of the neck and cap
PostPosted: Thu Aug 04, 2005 12:50 pm
thanx for that! cap is definitely different!!
PostPosted: Thu Aug 04, 2005 5:02 pm
sorry but it has to be said, "nice hand modelling there Jill!" :lol:
Aaron
PostPosted: Thu Aug 04, 2005 6:14 pm
The radiator cap on my Moke is just flat inside without any springs or such, only a flat piece of rubber inside it. The cap on the overflow tank is the normal looking type cap...
PostPosted: Thu Aug 04, 2005 6:55 pm
J_A_M wrote:
makka
`tis true.
Water is basically incompressible, and also expands when it gets hot. The excess goes out the filler past the 13psi? pressure relief valve in the cap.
When it cools down, it sucks air back in (thru the vacuum break valve in cap) the result is when you check it cold, it's looking a bit low.... :shock:
Important thing is- when it heats up next time it will merely displace this air back out the cap, so when it's hot it is actually full. But you can't see it. :lol:
PostPosted: Thu Aug 04, 2005 9:12 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
see even doc made what i said plasible ... wow big word
i'm right ha ha ha ha stick that in ya pipe and smoke it ... ok i'll settle down now
makka
PostPosted: Thu Aug 04, 2005 11:47 pm
Aaron
;) yeah, that is one of the 5 nails that has survived so far
but what about that beautiful clean and green coolant..? I thought that was impressive :)
