It is currently Thu Jul 10, 2025 7:46 am
 Post subject: C.S Mark2 dash trim
PostPosted: Sun Apr 29, 2018 5:24 pm
Hello All,
Just fitted the black vinyl dash trims ,top trim is easy to fit. The bottom trim which is the one where the switch panel is, a pain to fit .Although it is done now. I only have approx. 2 or 3 mm of vinyl in the opening where the switch panel fits. The aluminum switch trim just covers the vinyl .Has anyone had the vinyl shrink which would show the paint ? The aluminum switch panel trim should have been larger and made from SS. Took me 4 hours to do a 1 hour job.
Allen
 Post subject: Re: C.S Mark2 dash trim
PostPosted: Sun Apr 29, 2018 6:18 pm
When I have done them they haven't shrunk back yet
PostPosted: Sun Apr 29, 2018 7:53 pm
p7676 wrote:
Hello All,
Allen
Sounds about right.
The original vinyl doesn't shrink. If there was a lot of vinyl over-lapping the opening, I think the trim piece would not be able to hold back 2 thicknesses of vinyl.
No restoration job is predictable because you aren't doing it all the time.
If you planned on it being a 4 hour job you'd be pleased it was on time!
