1970 mini hand brake adjustment https://www.ausmini.com/forums/viewtopic.php?f=2&t=97303 |
Author: | p7676 [ Sun Jun 03, 2018 2:55 pm ] |
Post subject: | 1970 mini hand brake adjustment |
Hello All' I have fitted new hand brake cables and adjusted the rear brakes .The question is ,the hand brake adjustment nuts are screwed down below half way on the threads is that normal to get a good hand brake ???? Allen |
Author: | Bill B [ Sun Jun 03, 2018 5:54 pm ] |
Post subject: | Re: 1970 mini hand brake adjustment |
Have fitted new cables to my rebuild. The threaded section is about 80mm in total, there is about 40 mm sticking out past the round bar which the adjusting nuts rest on, including the height of the nuts. That's just over half way. My road going car is very similar. |
Author: | cooperess [ Sun Jun 03, 2018 11:15 pm ] |
Maybe you have a van set of hand brake cables which are longer than sedan! http://minisparesoz.com/mini-van-estate ... ed-per-car |
Author: | Bill B [ Mon Jun 04, 2018 11:54 am ] |
cooperess wrote: Maybe you have a van set of hand brake cables which are longer than sedan! http://minisparesoz.com/mini-van-estate ... ed-per-car Dry and hydro cars also have different cables. The cables I have just fitted have a small yellow plastic ring on each of them. I don't know if this is an identification code for specific application, or if it was just used by whoever made them. |
