It is currently Sun Jul 06, 2025 1:28 pm
 Post subject: white gooo
PostPosted: Thu Aug 04, 2005 1:34 pm
took the oil cap of my clubby the other day to top the oil up and i noticed this white sludge on the underside of the cap,it also had some condinsation in the form of drops of water,what do ya think,iv been told its normal. thanks guys :P
PostPosted: Thu Aug 04, 2005 1:38 pm
BLOWN HEAD GASKET!! Emolsified oil......
PostPosted: Thu Aug 04, 2005 1:43 pm
that dose not sound good :cry: i know what the head gskit is,any advice,should i not be driveing him,my engines been bored out as far as it will go and i dont want to f#!*ck it up
PostPosted: Thu Aug 04, 2005 1:46 pm
A little bit can be normal if the car has been sitting around or not driven long/hard enough to warm the motor up enough to drive out any condesation.
Check the coolant - if it looks similar then your up for a new head gasket :roll:
PostPosted: Thu Aug 04, 2005 1:51 pm
Like this?
http://www.ausmini.com/forums/viewtopic.php?t=9665
PostPosted: Thu Aug 04, 2005 1:55 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
also look at the oil on the dip stick to see if it is creamy
hanra a combustion motor get water from the fuel during combustion
makka
PostPosted: Thu Aug 04, 2005 2:16 pm
Or
Put the car in neutral and let it idle.
Go to the radiator and take the cap off.
If air bubbles come up through your radiator coolant more chance than not, it's the head gasket.
OR
If the cars hard to start, idling badly and using a lot of water. :wink:
PostPosted: Thu Aug 04, 2005 2:53 pm
Simple answer: Not enough crank case ventilation
I've seen 3 clubbies now that have this symptom.
Cure: Install tappet cover breather, rocker cover breather, flywheel housing breather, Take it for a LONG drive to Newcastle this weekend for the run and swap meet and she will be fine! :wink:
Better still install a PCV and never have the problem again
PostPosted: Thu Aug 04, 2005 2:56 pm
How does that affect the cooling system... how does the oil get into the water? :?
PostPosted: Thu Aug 04, 2005 3:00 pm
Water or oil!?!?!?
I believe he said "Sludge under the OIL cap"
 Post subject: Re: white gooo
PostPosted: Thu Aug 04, 2005 3:01 pm
Yes I wasn't seeing things. Ask the Doc. When you burn fuel, you produce small amounts of water vapour which, if not vented properly, gathers up and forms sludge. On a correctly vented engine this does not happen. I will say no more until you hear it from the Doc's own mouth :lol:
Signed: the apprentice :P
PostPosted: Thu Aug 04, 2005 3:06 pm
i would think that there would also have to be emulsified oil on the rockers too if the head gasket was blown?
PostPosted: Thu Aug 04, 2005 3:15 pm
It coats everything... betty has the bad case of Mayo! Still trying to recover from it... 2 crank case vents should do it.
OT
Makka: do Betty a favour and open up/connect the tappet cover breather that is blocked up. This should free up the ventilation enough for her to burn all that mayo off.
Next time I see her I will take the rocker cover off and clean the whole thing, I have a spare rocker cover gasket or two.
PostPosted: Thu Aug 04, 2005 3:19 pm
Also make sure you have a vented oil cap. I believe most pollution control Minis had the non vented variety and they tend to collect mayo a lot more. Mine had one (even though it's a 65 :? ) and I swapped for a vented cap and stopped mayo problems for good.
PostPosted: Thu Aug 04, 2005 4:04 pm
68Delux wrote:
Water or oil!?!?!?
Alright... that's enough from me for today. I'm officially turning retarded. :oops:
Users browsing this forum: No registered users and 69 guests
