thermo fan https://www.ausmini.com/forums/viewtopic.php?f=2&t=9832 |
Page 1 of 2 |
Author: | 64morris [ Sat Aug 06, 2005 8:22 pm ] |
Post subject: | thermo fan |
well my mini appears to be heating up a bit too much. The gauge reads 140 degrees all the time but i think it is wrong. I am thinking about installing a thermo fan to help with this. can anyone tell me how to go about finding one and fitting it? how much are they worth and do they help much? also is it common for minis to heat up during running in? and if the radiator is full nearly to the brim will the excess be sprayed out? |
Author: | 9YaTaH [ Sat Aug 06, 2005 8:29 pm ] |
Post subject: | Re: thermo fan |
[quote="64morris"][/quote] well my mini appears to be heating up a bit too much...they do that ![]() The gauge reads 140 degrees all the time but i think it is wrong....better get it checked or take out the sender and put it in boiling water and see what the guage reads ![]() I am thinking about installing a thermo fan to help with this...won't help a faulty guage ![]() ![]() can anyone tell me how to go about finding one and fitting it?...Davies Craig make em...look in the Yellow Pages for their advert ![]() ![]() how much are they worth and do they help much?....over a hundred bucks ![]() ![]() also is it common for minis to heat up during running in?..Damn straight ![]() ![]() and if the radiator is full nearly to the brim will the excess be sprayed out? Yep ![]() ![]() |
Author: | scotty [ Sat Aug 06, 2005 8:31 pm ] |
Not sure if it's normal during the run-in process. But before splurging on a thermo fan, best to see if there is a problem to sort out. Things to look at would be thermostat, radiator (that it isn't full of junk), possibly the carbs - make sure they're not running too lean. There are other areas, but I have a headache now and can't think straight ![]() |
Author: | 9YaTaH [ Sat Aug 06, 2005 8:34 pm ] |
Post subject: | Quick! |
scotty wrote: Not sure if it's normal during the run-in process. But before splurging on a thermo fan, best to see if there is a problem to sort out. Things to look at would be thermostat, radiator (that it isn't full of junk), possibly the carbs - make sure they're not running too lean. There are other areas, but I have a headache now and can't think straight
![]() Go and have a lie down Scotty..by the look on your face you have gas ![]() ![]() |
Author: | 64morris [ Sat Aug 06, 2005 8:36 pm ] |
the gauge sender has an adaptor fitted to it as it is to small / big for the hole. i have been told this may give false readings and that the ohms may be reversed or something. Quote: thermostat, radiator (that it isn't full of junk), possibly the carbs thermostat = tested, working radiator = brand new and the carb hasnt been tuned properly yet since the engine rebuild. Quote: do you have antifreeze/antiboil coolant in there
yep. this is a good answer because today i was stopping every 10 - 15 mins to check evertything and the first couple of times found coolant all over the firewall. then when it had sprayed out enough to lower the level it stopped doing this. |
Author: | 64morris [ Sat Aug 06, 2005 8:43 pm ] |
so where do i get the appropriate thermo fan? it would be the easiest solution, yes? is there any body mods required to fit one? |
Author: | scotty [ Sat Aug 06, 2005 8:45 pm ] |
Post subject: | Re: Quick! |
9YaTaH wrote: scotty wrote: Not sure if it's normal during the run-in process. But before splurging on a thermo fan, best to see if there is a problem to sort out. Things to look at would be thermostat, radiator (that it isn't full of junk), possibly the carbs - make sure they're not running too lean. There are other areas, but I have a headache now and can't think straight ![]() Go and have a lie down Scotty..by the look on your face you have gas ![]() ![]() ![]() |
Author: | 9YaTaH [ Sat Aug 06, 2005 8:45 pm ] |
Post subject: | Ummm |
64morris wrote: yep. this is a good answer because today i was stopping every 10 - 15 mins to check evertything and the first couple of times found coolant all over the firewall. then when it had sprayed out enough to lower the level it stopped doing this.[/quote]
What sort of running ![]() [quote="64morris"]the gauge sender has an adaptor fitted to it as it is to small / big for the hole. i have been told this may give false readings and that the ohms may be reversed or something.....needs to be sorted...not enough information to say something useful to you...sorry ![]() thermostat = tested, working ...KAY radiator = brand new...............KAY and the carb hasnt been tuned properly yet since the engine rebuild...................................BINGO first thing to check before you melt your new engine ![]() |
Author: | 64morris [ Sat Aug 06, 2005 8:49 pm ] |
yeh i was on the highway a fair bit today. up and down through the revs alot. but i was only game to take it to 4000rpm in 4th and about 3-3.5k in 2nd, 3rd is that not enough? |
Author: | scotty [ Sat Aug 06, 2005 8:50 pm ] |
Post subject: | Re: Ummm |
9YaTaH wrote: thermostat = tested, working ...KAY
radiator = brand new...............KAY and the carb hasnt been tuned properly yet since the engine rebuild...................................BINGO first thing to check before you melt your new engine ![]() ![]() ![]() ![]() ![]() ![]() |
Author: | 64morris [ Sat Aug 06, 2005 8:51 pm ] |
so what do i do about that. how bad is it for the engine? |
Author: | mini_van_1970 [ Sat Aug 06, 2005 9:03 pm ] |
I think that there is a post on here somewhere that shows the pistons fried from running to rich or lean or something along those lines, but the idea would be to go to the local dyno shop and get them to give a tune-up and put the right needle in it What size 1275 you running? Pat |
Author: | 64morris [ Sat Aug 06, 2005 9:12 pm ] |
1310. i have a 42 weber that will be going on soon so is it safe to drive locally with the current carb until the weber is fitted and tuned? |
Author: | 9YaTaH [ Sat Aug 06, 2005 9:16 pm ] |
Post subject: | Yeah... |
64morris wrote: yeh i was on the highway a fair bit today. up and down through the revs alot. but i was only game to take it to 4000rpm in 4th and about 3-3.5k in 2nd, 3rd is that not enough?
Yeah...seems OK....main thing is to change on the torque curve rather then power curve and valve bounce ![]() |
Author: | 64morris [ Sat Aug 06, 2005 9:18 pm ] |
yeh i tried to keep it easy up hills. so will this badl tuned carb kill the motor quick? |
