It is currently Fri Aug 22, 2025 3:55 am
PostPosted: Thu Apr 09, 2020 1:32 pm
Hard to see but one handle has the key reference number and the other does not.
See the top screw hole.
My question is. At what stage did this change?
PostPosted: Thu Apr 09, 2020 2:00 pm
Are they both lockable handle escutcheons?
What is the cast part number - HYA ????
PostPosted: Thu Apr 09, 2020 2:27 pm
Both handles are numbered HYA2802 312
PostPosted: Thu Apr 09, 2020 2:45 pm
Yes, that's for the handles. What about on the escutcheons?
Is the lower handle just missing the spring, flat washer and split pin to hold it to the escutcheon?
Ignore this. Misread the first post.
PostPosted: Thu Apr 09, 2020 9:53 pm
I found no part numbers on the escutcheons.
PostPosted: Thu Apr 09, 2020 10:10 pm
What about these ones
PostPosted: Thu Apr 09, 2020 10:25 pm
Had a look at some bits - 1 complete handle has the FS key code on the middle screw boss of the escutcheon but several others do not.
PostPosted: Fri Apr 10, 2020 9:29 am
I have looked harder today and found part numbers on both the escutcheons.
Top picture FS947 and HYA2795
Bottom picture HYA2795
PostPosted: Sat Apr 11, 2020 8:01 am
Back to my original Mini Chat.
My question is. At what stage (date) did they change the escutcheons?
PostPosted: Sat Apr 11, 2020 9:43 am
Since they are both the same part number, it looks like the makers simply remade the mould for inner pattern of the casting. That might be lost in the records of "Certizinc".
PostPosted: Sat Apr 11, 2020 11:07 am
I thought there might be some info on the engineering drawing but I don't have access to HYA2795 to check. The FS947 is the key number.
PostPosted: Sat Apr 11, 2020 11:21 am
Maybe this new info is another way to ID the windup windows Mini.
Does the key number help date a Mini?
PostPosted: Sat Apr 11, 2020 12:12 pm
Is the only difference between your escutcheons the stamped key number on one and missing on the other? One has a rubber gasket hiding full view of the under section.
If so the casting is the same and the location of the key number has changed.
Not really. There was a range of key combinations that were randomly used and reused across various BMC models.
PostPosted: Sat Apr 11, 2020 12:19 pm
I have seen many key codes stamped on the square key(way) but less on the escutcheon.
My thoughts in answer to your Q, as the escutcheon is easily changed - and / or handle to eliminate wear movement - and is separate to the barrel (and the square key), the stamp on the escutcheon would then have confusing reference to the FS coded key barrel. So stamping the square key(way) was more an obvious solution?
Users browsing this forum: No registered users and 258 guests
