Enigne Is Healthy
https://www.ausmini.com/forums/viewtopic.php?f=2&t=9888
Author:  1380 yellow devil [ Mon Aug 08, 2005 1:36 pm ]
Post subject:  Enigne Is Healthy
All put back together and running Fine.
I req new thrush washer of 3 thou over size and I think the wrong ones were put in when it was Built.
No I have clutch Problems and it will not disengage correctly I have checked the adjustements on the Reeas lever But I have found that the lever is not getting Pushed far enough with the Pedal is depressed. Any susgestions on what can be done to fix would be great.
Author:  9YaTaH [ Mon Aug 08, 2005 6:28 pm ]
Post subject:  Bend zee knees
So are we talking about the situation now where Slave Cylinder lever ball being worn away so much that people either end the lever or fir and extension (adjustable) to the slave cylinder rod :? :oops: :roll:
Author:  1380 yellow devil [ Tue Aug 09, 2005 12:14 pm ]
New lever has been installed and new pins for the lever at the top and bottom.
