Carb needles for twin HS4s and Ramflo filters, on a 1293? https://www.ausmini.com/forums/viewtopic.php?f=2&t=9894 |
Page 1 of 2 |
Author: | drmini in aust [ Mon Aug 08, 2005 5:14 pm ] |
Post subject: | Carb needles for twin HS4s and Ramflo filters, on a 1293? |
OK Barney's 1293 is not going bad, but he's a bit lean between idle and 3500rpm. From there to 7000 it's all go-go-go. Cam is a Tighe 104, he has ToyoMini (ie Corolla) 1.46:1 rockers & rimflo valves. Needles in now are #6. I has CP4s in but the #6 are better up high. So, all you guys with a Fuzzpack Cooper S, what needles are you running? ![]() Greig Malaure says I may have to get the file out. I have some `needle files'.. ![]() ![]() |
Author: | GT1360 [ Mon Aug 08, 2005 5:23 pm ] |
no idea off the top of my head. I know the ones that were in them before had been filed down.. I have given up on twins.. never again ![]() |
Author: | gafmo [ Mon Aug 08, 2005 10:54 pm ] |
give Bill Silvertsen a Call (Silvo) at Midel Dr |
Author: | ELMO [ Tue Aug 09, 2005 12:53 am ] |
Haven't quite finished rebuilding my HS4's for my 1275A+ plus.020 but I am putting in BG needles to initial start with as I am told these are the basic COP needles they used. |
Author: | drmini in aust [ Tue Aug 09, 2005 7:00 am ] |
ELMO wrote: Haven't quite finished rebuilding my HS4's for my 1275A+ plus.020 but I am putting in BG needles to initial start with as I am told these are the basic COP needles they used.
Karcraft told me it was CP4s they used...?? I know there was some needle confusion at the time.... Vizard suggests #3 or #4. I think I'll try #3 next, as I have a pair. ![]() |
Author: | TheMiniMan [ Tue Aug 09, 2005 9:56 am ] |
Hey kev... You could try any number of these needles,,,they all will produce a richer bottom end than the CP4s or MMEs or #6 type needles AS CS1 FG P6 R6 RLB RLS we can fine tune things over the net after all mate ![]() ![]() ![]() ![]() easy-peasy ![]() ![]() ![]() |
Author: | doorlady [ Tue Aug 09, 2005 12:59 pm ] |
Has any body tryed this program I have downloaded it but not sure how accurate it would be it lets you put your mods in and gives you a suggested needle size. http://www.winsu.co.uk/ |
Author: | 1380 yellow devil [ Tue Aug 09, 2005 2:01 pm ] |
doorlady wrote: Has any body tryed this program I have downloaded it but not sure how accurate it would be it lets you put your mods in and gives you a suggested needle size.
http://www.winsu.co.uk/ Yeah I have and It worked a treat and Still have not quite found the correct one for my HIF as it still lean down low and lacks the torque. The othere needles all have a richer top end and I do not want it any richer up there. |
Author: | drmini in aust [ Fri Aug 12, 2005 8:24 pm ] |
OK Barney finally got his problem sorted today with the help of GR's fuel/air meter. His #6 needles in the HS4s were spot on. It was actually going real rich (reading around 10 or 11) between idle and 3000 rpm, as the 20W/50 oil was restricting the SU pistons from rising. Drained the oil out, he's running fine now, with NO damping at all... ![]() |
Author: | doorlady [ Fri Aug 12, 2005 8:37 pm ] |
OK at the risk of sounding like a dick ![]() ![]() Or is not a SU at all. |
Author: | 9YaTaH [ Fri Aug 12, 2005 8:42 pm ] |
Post subject: | Needle Files |
drmini in aust wrote: OK Barney finally got his problem sorted today with the help of GR's fuel/air meter.
His #6 needles in the HS4s were spot on. It was actually going real rich (reading around 10 or 11) between idle and 3000 rpm, as the 20W/50 oil was restricting the SU pistons from rising. Drained the oil out, he's running fine now, with NO damping at all... ![]() Just when I was gunna donate my old needle files to use....he sorts it out ![]() I won't ask why the twenny dubya fifty was in their Doc....somethings ya just don't ask ![]() We have a member here with an ex-Police Cooper S MKII....I will try and find out what needles he is running (may be a lost cause after all these years...most probably fiddled with) ![]() |
Author: | drmini in aust [ Fri Aug 12, 2005 8:45 pm ] |
Doorlady, an HS4 is an SU, 1-1/2". Mick, I put the 20W50 in... had to start somewhere. No flats spots now with them empty, so it can stay like that for a while. ![]() |
Author: | TheMiniMan [ Fri Aug 12, 2005 8:56 pm ] |
what springs are you running with that set up Doc? |
Author: | drmini in aust [ Fri Aug 12, 2005 8:58 pm ] |
TheMiniMan wrote: what springs are you running with that set up Doc?
Buggered if I know, Matt. Paint on end all gone.. Graham said they are working OK so leave in. ![]() |
Author: | J_A_M [ Fri Aug 12, 2005 9:00 pm ] |
no damper oil?? wtf?? |
