It is currently Tue Jul 22, 2025 1:43 am
 Post subject: Enigne Is Healthy
PostPosted: Mon Aug 08, 2005 1:36 pm
All put back together and running Fine.
I req new thrush washer of 3 thou over size and I think the wrong ones were put in when it was Built.
No I have clutch Problems and it will not disengage correctly I have checked the adjustements on the Reeas lever But I have found that the lever is not getting Pushed far enough with the Pedal is depressed. Any susgestions on what can be done to fix would be great.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
1970 Mini K, 1380cc, 1.75 HIF SU, 30 70 Cam, 2" Zorts
1969 Mini K, Stock Standard and Orginal. (Slow as Hell)
 Post subject: Bend zee knees
PostPosted: Mon Aug 08, 2005 6:28 pm
So are we talking about the situation now where Slave Cylinder lever ball being worn away so much that people either end the lever or fir and extension (adjustable) to the slave cylinder rod :? :oops: :roll:
PostPosted: Tue Aug 09, 2005 12:14 pm
New lever has been installed and new pins for the lever at the top and bottom.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
Users browsing this forum: Majestic-12 [Bot] and 97 guests
