Well guys and girls here is the problem.
Put Slidey on a tilt tray friday and off we went to a workshop at Bowen Hills to get his clutch issues fixed.
Now i purchased a new adjustment arm, clevis pins, thrust bearing and all other relative items to hopefully recitfy the issue. If they didn't work i told the head mechanic to change over the master cylinders from .7 to.75 to give a bit more pedal so to speak......... failing that replace the slave cylinder.
Now this arvo i get a call from the mechanic saying "we couldn't get the adjustment right for the clutch so we will have to take the engine out
... i ask did you put the parts i bought in?????? Silence on the other end of the line....... "no"
Now i don't know much about the mechanical side of mini's..... but i'm damn sure i would be putting in the new arm, clevis pins and the thrust bearing before i adjusted again, deeming that they are most likely f&*ked (which is why i bought them in the first place.....
Even more, i thought that clutches in mini's could be changed in car..... lefthandside engine mount released, lefthand side engine steady off, jack the block under the sump plug, jack up, cover off flywheel puller on pop off the flywheel and away you go...........
Is that right???
I also am beggining to think that i wasted a tilt tray trip to bowen hills because i think that they know absolutely squat about mini mechanics.............
What should i do???
