It is currently Wed Aug 06, 2025 5:10 am
PostPosted: Tue Aug 09, 2005 8:21 pm
High heel ninja
Finally got around to changing the driver side steel hydrolastic pipe in the missus clubman, yuck yuck yuck what a horrible job
Apart from having to drop both subframes i also had to
Drain & remove both fuel tanks
Disconnect rear hydro springs
Remove exhaust
Loosen off handbrake cables
unbolt the remote
disconnet front shocks
Remove the battery
remove the slave cylinder
disconnect both pipe to the master cylinders
loosen off steering rack
Then i had trouble realigning the front subframe.
It was horrible i hated every minute of it, but my new aluminium trolley jack worked a treat.
Doogie
PostPosted: Tue Aug 09, 2005 8:23 pm
better you then me mate. :P thats a big job for a fairly small part. lol :cry:
PostPosted: Tue Aug 09, 2005 8:26 pm
Doogie,
How long did that take you?
Ziff
PostPosted: Tue Aug 09, 2005 8:28 pm
High heel ninja
All up about 3 and a bit hours to do the whole lot. Did it while the motor racing was on channel 10 on sunday. Still have to give the brakes one more bleed
Doogie
PostPosted: Tue Aug 09, 2005 8:32 pm
Hmmm... wonder how long the LH one will last now... 8)
PostPosted: Tue Aug 09, 2005 8:34 pm
3 hrs, thats awesome. Good job :D
Ziff
PostPosted: Tue Aug 09, 2005 8:35 pm
High heel ninja
Don't go there Doc!!!!!!
Doogie
Who loves dry cone suspension
PostPosted: Tue Aug 09, 2005 10:38 pm
Doogie
Me.
Bob Slattery
PostPosted: Wed Aug 10, 2005 8:37 am
Doogie
now THAT is a sh*t job!!!
