What a nightmare, NEVER AGAIN https://www.ausmini.com/forums/viewtopic.php?f=2&t=9940 |
Author: | doogie [ Tue Aug 09, 2005 8:21 pm ] |
Post subject: | What a nightmare, NEVER AGAIN |
Finally got around to changing the driver side steel hydrolastic pipe in the missus clubman, yuck yuck yuck what a horrible job Apart from having to drop both subframes i also had to Drain & remove both fuel tanks Disconnect rear hydro springs Remove exhaust Loosen off handbrake cables unbolt the remote disconnet front shocks Remove the battery remove the slave cylinder disconnect both pipe to the master cylinders loosen off steering rack Then i had trouble realigning the front subframe. It was horrible i hated every minute of it, but my new aluminium trolley jack worked a treat. Doogie |
Author: | GT1360 [ Tue Aug 09, 2005 8:23 pm ] |
better you then me mate. ![]() ![]() |
Author: | ziff [ Tue Aug 09, 2005 8:26 pm ] |
Doogie, How long did that take you? Ziff |
Author: | doogie [ Tue Aug 09, 2005 8:28 pm ] |
All up about 3 and a bit hours to do the whole lot. Did it while the motor racing was on channel 10 on sunday. Still have to give the brakes one more bleed Doogie |
Author: | drmini in aust [ Tue Aug 09, 2005 8:32 pm ] |
Hmmm... wonder how long the LH one will last now... ![]() |
Author: | ziff [ Tue Aug 09, 2005 8:34 pm ] |
3 hrs, thats awesome. Good job ![]() Ziff |
Author: | doogie [ Tue Aug 09, 2005 8:35 pm ] |
Don't go there Doc!!!!!! Doogie Who loves dry cone suspension |
Author: | MrBob [ Tue Aug 09, 2005 10:38 pm ] |
2 S's & a clubman wrote: Don't go there Doc!!!!!! Me.
Author: | J_A_M [ Wed Aug 10, 2005 8:37 am ] |
2 S's & a clubman wrote: Still have to give the brakes one more bleed
Doogie now THAT is a sh*t job!!! |
