It is currently Tue Jul 22, 2025 1:17 pm
Post new topic Reply to topic  [ 360 posts ]  Go to page Previous  1 ... 20, 21, 22, 23, 24
PostPosted: Mon Nov 06, 2023 1:15 pm
Hi All,
So I finally had a new website built a while back and had to figure out how to re-host all the photos. Hopefully this is working for everyone now.
In other news I took the Morris to Calder Park drags last friday. Never having done it before I didn't know what to expect, but the car ran 14.98 first go. Massive traction issues which I hope to sort soon, but pretty happy with that result:)
Madmorrie
Madmorrie
https://www.youtube.com/watch?v=oczLolENFMQ
PostPosted: Tue Jun 25, 2024 1:27 pm
So here's the best video of my runs at Calder. I have since fitted the good wheels and stickier tyres so next time out will be interesting.
https://www.youtube.com/watch?v=TGb88u--zoA
Madmorrie
PostPosted: Tue Jun 25, 2024 9:32 pm
damn, the guy in Skyline must have been pissed!
:D
PostPosted: Wed Jun 26, 2024 1:44 pm
Wow, people still read this?
And yeah, while I technically 'won' on the timesheet, his 10.5 was significantly faster. He may have seen how much I was moving around the lane on my first run and wisely decided to hang around on the start line for a bit:)
In lieu of an actual update. Here's how the car looked a few days back, right before I swapped these tyres out for some slightly more sensibly sized ones. These 185s looked ace, but did rub a little too much.
Madmorrie
PostPosted: Sun Jul 28, 2024 12:45 pm
The Morris is entered for Summernats, so I have to get it finished and painted by end of December, to then roadtrip it to Canberra. I have two of the hanging panels painted, and they came out great. It's going to hurt a little to cut a big hole in that bonnet!
The rest of them in the shed for prep. However it is currently too cold to paint:(
I've also decided to try to document this journey in video form. Because finishing a project car is not enough of a challenge, I might as well add filming and editing to the large pile of tasks that need to be done by then...
Anyway, https://youtu.be/Z1JNAOglqRI
Madmorrie
PostPosted: Fri Sep 27, 2024 12:07 am
One of the hardest and most time consuming things on this car has been sorting better brakes. The stock system is barely adequate for spirited driving with the factory performance, so tripling the horsepower certainly requires a suitable increase in stopping power also.
I have literally spent hours and hours combing through the internet, magazines, the DBA catalog and anywhere else I could find to figure out a way to get bigger brakes under this thing. Strangely enough nobody makes a big brake kit for a Morris 1100.
Years ago I bought a fancy Tarox big brake kit designed for a Mini from another member on here. Given the interchangeability of some mechanicals I had hoped it would work, but it was not to be. Those featured a 234mm disc and nice alloy mounting bells plus six pot alloy calipers. All lovely stuff, but when I would have to remake the mounting brackets and bells, only using half the kit hardly seemed worth it, and so they were on-sold.
The Metro turbo vented discs are the largest bolt on solution I could get at 213mm x 20mm. At one point I even looked at Austin princess brakes, which were 270mm diameter, as they seemed like they would also bolt on, however they were not vented and I doubt would fit inside any wheel I could make work.
The brakes I have fitted (Metro turbo vented discs with Renault Clio sliding single calipers) did pass the engineering brake test, but only just. And my engineer did recommend I fit a booster.
I improved them somewhat with some EBC greenstuff pads, but fitting a booster was always going to be a pain given the late mini split master cylinder braking system.
After much head scratching and poring over the DBA catalog, I settled on Ford Econovan brake discs as a possible option. They are 256mm diameter, 20mm wide and have a big enough hole in the middle to fit over the CV, and are basically flat like the motorsport style discs, just much cheaper. So with a suitable mounting bell made they looked like they just might work.
Econovan Disc
With those in my hand I fired up the CAD software and tried to see what sort of shaped I'd need. After many iterations I finally arrived at something I liked, I then 3d printed a model and took it out to the shed to verify my work.
Disc with Mockup bell
Econovan discs vs Metro Turbo
While initially I had hoped to reuse the Clio calipers by simply moving them outboard, it meant that the mounting holes clashed with the hub and just got problematic. However some rx7 4 pots came up cheap on market place so I figured I'd give them a shot. Their much wider bolt spacing made it physically possible to fit with an adapter.
3D printed caliper mount mockup number 5.
RX7 caliper on the larger disc
Mockups showed that the brake bell geometry was spot on, but I made a new design to use bolts and nuts instead of threaded holes at the disc mount. And I went thru 5 iterations for the caliper bracket to position it where I needed it while still allowing access to the grease nipples.
With the design sorted I uploaded the files to JLCPCB and sent them some money.
Final Brake Bell Design
RX7 Brake Caliper Mount
And so all this leads me to the shiny bits that arrived in the post today. They turned out awesome, now I just need to get some new bolts for all this and we can mount them up.
Madmorrie
PostPosted: Fri Sep 27, 2024 9:14 pm
This is bloody spectacular! Well done.
PostPosted: Wed Oct 09, 2024 10:52 pm
So the bolts have arrived to fit the brakes, but I just dropped the seats off to be re-trimmed so while I might get time to fit them up soon, they won't be able to be tested for a while.
I have been messing around with lots of little things on the car. One idea that I have toyed with for ages is a custom badge. If we are honest, the Morris badge is a little pedestrian. Given I have injected a lot more attitude into the car a lot I thought I might take a look at modernising the badge a little too. (Or if you prefer, since I have bastardised nearly every other part of the car...)
And while I have de-badged the outside of the car, the inside could do with a little bit of jewellery.
I do love the original Morris 'M' horn push, but all the ones I have are damaged in some way. The nice SAAS wheel I have came with a nice machined alloy centre, but it's just a bit bland.
Anyway, since I was trained as a graphic designer I fired up illustrator and had a muck around.
The original Ox we know and love.
My first attempt. A bit better, but I was thinking it needed more "Raging Bull" style?
Hmm, more comical than I was hoping for. At this point I walked away from it for months.
Came back with fresh eyes much later and found better reference.
Which distilled into this.
And finally this.
And since my car will be yellow and black. I created this version.
Happy with that I set about making it real. I extruded to logo in blender and 3D printed it at the size I needed. I've just used PETG filament which is what I use most of the time. Will see how it lasts in the summer.
I had some clear epoxy left over from a table project I did a few years back. With some raiding of the arts and crafts box and quite a bit of experimentation I managed to create this.
Pretty happy with how it came out. Time will tell if it lasts or not.
Madmorrie
PostPosted: Fri Oct 11, 2024 7:37 am
Very cool. Love how you have a finger print on every aspect of this build. Truely custom and better than factory.
1966 Mini Deluxe - “Gabby” 34 years under restoration and counting...
1970 MGBGT
1959 MGA
PostPosted: Sun Oct 13, 2024 5:27 am
amazing!!!!
PostPosted: Tue Dec 17, 2024 9:16 am
So having set the goal of finishing this car for Summernats earlier in the year I have been busily working away in my shed bodyworking and painting panels one by one. I know this is not the best way to do it, but it has meant I got it done. The makeshift booth I made in my shed is not large enough to fit the car, and with nothing else 'unboltable' I had to figure out a different plan.
By alternately working on the back, then the front, I managed to paint strip, epoxy prime, fill and smooth, then re-prime all the panels on the car. My plan was then to do one colour coat at home to then rub back ready for more colour at the paint booth, however I only managed to get to this on the back.
So last Saturday, with the body work done as well as I could get it in the time frame, I loaded the car onto a trailer and took it to a spray booth to get a proper spray job. I roped in my mate Toby, who just so happens to be a much better painter than me, to help for the day, and in the end he shot the whole car and it came out bloody fantastic!
I still have my work cut out for me to meet my deadline, but am now confident the car will look sensational when it's done.
Madmorrie
Note the Hydro pumped up extra high for ease of painting:) Will be re-Lowed once it's all back together.
Madmorrie
PostPosted: Mon Jan 06, 2025 11:03 am
Hi Madmorrie, I was watching your Youtube video about the brakes, and was very impressed. They seem to have worked out really nicely. Is it a requirement to have the modifications assessed by an engineer?
And, did you make it to Summernats?
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Mon Feb 17, 2025 10:39 pm
I must say, it looks really hot in that shade of yellow - nice work!
PostPosted: Thu Feb 27, 2025 12:05 am
Thanks all,
The car and I did make it to Summernats OK. And the car was well received by a certain subset of the crowd there. I did get picked to go in the supercruise in the main arena which was fun.
This is the final assembly video.
https://www.youtube.com/watch?v=YpAPBUUpZks
And Tim, Yes I probably do need to get the braked re-engineered. They have been made with that in mind, no welded brackets, ADR'd calipers with dust seals etc, so they should pass fine when I get round to it.
Anyway, here is how it finished up looking.
Madmorrie
Madmorrie
PostPosted: Thu Feb 27, 2025 6:40 am
Love the video , have enjoyed watching the build , excellent work 8) .
