It is currently Sat Jul 05, 2025 12:11 pm
PostPosted: Mon Sep 05, 2005 4:47 pm
very neet but you should try to drop the lp pumps to below the bottom of the fuel tanks.... this will help to keep the pumps flooded so that the annoying start up noise dose not exist.... this also applies to the hp pump under the surge tank bottom line..... Also try to tap into the bottom of the surge tank for the hp pump feed.... good luck....
PostPosted: Mon Sep 12, 2005 12:38 pm
i'm with him.. LP pumps should be below the tanks, they're fine under the car, just put em somehwere up out of the way of stuff you drive over..
they dont have enough pressure to suck fuel up..
plus you should soft mount em.. they click like a bastard once pressure is reached
Expert in training
PostPosted: Mon Sep 12, 2005 7:14 pm
The whole plate is soft mounted on rubbers.
As far as the LF pumps, I will see how they go when i start them up.
Dan
PostPosted: Tue Sep 13, 2005 3:28 pm
your biggest concern is the hp pump....lower it and put a bottom drain out of the swirl pot.... if the bosch runs dry they f&$k out easy.....
