It is currently Sat Jul 05, 2025 3:53 pm
PostPosted: Thu Oct 13, 2005 4:57 pm
For those needing to work out if you need your speedo recalibrated:
http://www.tyremaster.com.au/fitment_tips/diam_calc.htm
Just divide the donor car rolling diameter by your new rolling diameter & multiply by 100 to get the percentage change.
PostPosted: Thu Oct 13, 2005 5:05 pm
For example:
Subaru 195 / 65 R 15 = 1993mm
now 185 / 65 R 14 = 1873mm
100 x 1993 / 1873 = 106.4
so my speedo will read 6.4% higher.
This is just an example, as I don't know what rims were on the original
PostPosted: Fri Oct 14, 2005 9:06 am
ok see if i got this right
mine now is 175/50/13 = 1587mm
starlet is 185/60/14?? = 1815mm
so i get 114,36
so 14% out?
1974 Moke - 998cc
PostPosted: Fri Oct 14, 2005 11:03 am
You got it :)
You didn't get yours recalibrated then?
