minimetoy wrote:
Ohhhhhhh, more sleepless nights ahead.
Yep thought the same inazuma, but the only real drama was the dump pipe was going to be right next to the dizzy (melt down). I also thought about having the turbo reversed and the dump pipe facing the grille, still a possibility???
As i write this the ballance of my plates have turned up, look great. This means i now need to make a decision, do i leave it or do i play with it??
Dan
piss the dizzy off and go a coilpack? i believe they make these for the 4e-fte...not sure though...
edit: will require a new ECU probably...but it appears to be the route bara went with his...dunno but those things connected to his firewall sure look like coil pack gear to me
