It is currently Fri Jul 04, 2025 8:06 pm
PostPosted: Mon Sep 10, 2012 7:06 pm
i have just made a sub fame, motor mounts, drive shifts, gear and motor rods and alum intake from the jigs i made of the blue 68 turbo mini
the same as this one
http://www.youtube.com/watch?v=tWfMLhHXqNo
all the hard work done.
$2500
email [email protected]
thx
jason
<script src='http://imageshack.us/shareable/?i=img03351e.jpg&s=259' type='text/javascript'></script><noscript>Image</noscript>
i have 2 sub fame here so i can make two more kits about week work
PostPosted: Tue Sep 11, 2012 8:11 am
Looks Good.
The angles and clearances are interesting. A few questions for you.
- Do you run equal length drive shafts?
- Are the drive shafts one piece?
- With the engine at such an upright angle does the water pump pulley foul with standard suspension? I notice you have spring coils on that setup.
- Does your subframe and mounts suit a MK1 or Mk2 gearbox?
- On that particular vehicle where is the radiator?
 Post subject: kit
PostPosted: Thu Sep 13, 2012 7:33 pm
drive shafts one is longer by 40mm
shafts are two bits
yes well need coil hi lows
kit is for swift GTi 1989 to 1998 or MK2/MK3
rad is in the rear on turbo and well fit mini rad in the front
 Post subject: kit
PostPosted: Fri Sep 14, 2012 9:20 pm
<script src='http://imageshack.us/shareable/?i=img04121m.jpg&s=525' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://imageshack.us/shareable/?i=img04101z.jpg&s=706' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://imageshack.us/shareable/?i=img04091.jpg&s=255' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://imageshack.us/shareable/?i=img04081.jpg&s=713' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://imageshack.us/shareable/?i=img04071f.jpg&s=684' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://imageshack.us/shareable/?i=img04061w.jpg&s=713' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://imageshack.us/shareable/?i=img04051j.jpg&s=109' type='text/javascript'></script><noscript>Image</noscript>
<script src='http://imageshack.us/shareable/?i=img04041n.jpg&s=35' type='text/javascript'></script><noscript>Image</noscript>
PostPosted: Sat Sep 15, 2012 7:21 pm
does that collar get welded on to both shafts?
 Post subject: welding
PostPosted: Sat Sep 15, 2012 9:28 pm
yes well be heated to about 250 c + for a 1 hr then weld up with tig then back in for 2 hrs at 250 c +
 Post subject: kits
PostPosted: Mon May 13, 2013 6:52 pm
just about to make 3 kits 1 for my 66 mini and 2 for any one want can hlep with all fitting
thx
jason
PostPosted: Mon May 20, 2013 12:45 am
so what comes in the kit exactly?
the OP is a bit vague on details
 Post subject: call
PostPosted: Mon May 20, 2013 2:49 pm
give me a call mate
thx
jason
043322710
