Mearcat 4E-FTE Clubman Build (Latest update 5-05-24 Pg 28) https://www.ausmini.com/forums/viewtopic.php?f=23&t=60133 |
Page 10 of 28 |
Author: | Mearcat [ Wed Jan 04, 2012 11:46 pm ] |
Thanks Tricky. The core size of the factory top mount intercooler is 185 x 185 x 65. The intercooler core that will fit under the limited space in the LHS of the slam panel is 15% larger than stock (270 x 190 x 50) even with 50mm width end tanks. The front mount position combined with an intercooler water spray controller should get some reasonable effeciency gains over the factory size & position - since I'm using the standard CT9 turbo and only tweaking the boost up a little over stock. Time for an MDF mock up... |
Author: | Archangel007 [ Thu Jan 05, 2012 8:22 pm ] |
Best of luck Al!! |
Author: | Kennomini [ Mon Jan 30, 2012 6:23 pm ] |
Nice and neat but a bit of a shame hiding those cool bends in the manifold. |
Author: | Archangel007 [ Mon Jan 30, 2012 7:11 pm ] |
Yes Al, nice work there mate. Keep it up!! |
Author: | Mearcat [ Mon Jan 30, 2012 8:40 pm ] |
Kennomini wrote: Nice and neat but a bit of a shame hiding those cool bends in the manifold.
The main reason for hiding those cool bends is because I didn't get approval for that specific manifold in my modification application to the Dept of Transport, so it's just my paranoia... hide it so they can't pick on it. |
Author: | Kennomini [ Tue Jan 31, 2012 10:05 pm ] |
Author: | madmorrie [ Tue Jan 31, 2012 11:07 pm ] |
It's probably a pollution control thing. Engine must be as per the manufacturers specs, who made it to comply with whatever regs, therefore if you change something it alters that. Yes the manifold probably won't change emissions that much, but try telling that to a pen pusher who will just point to the rule in the book and shake their head. Anyway, I reckon that looks pretty good, you just need to panel beat in the word 'HOT' into the top of that and it will look fully factory and no one will ever pick it... Madmorrie |
Author: | Mearcat [ Wed Feb 01, 2012 12:13 am ] |
Sorry guys - Let me clarify the lack of approval. It's not that they didn't approve it. I didn't include the manifold in the original application because I hadn't thought of fitting one when I submitted the application. Given the hoops I've already jumped through, I can't be bothered resubmitting the application to add that one thing. It will be easy enough to remove the heat shield after registration. |
Author: | Archangel007 [ Wed Feb 01, 2012 8:21 pm ] |
It doesnt affect anything Alan and they dont need to know about it - simple!! |
Author: | JC [ Thu Feb 02, 2012 1:13 am ] |
Be VERY VERY careful around the top right hand side stud/bolt where manifold bolts to the head. The stud is prone to coming away from the head. Trust me, I was unfortuante enough to find out the hard way. If you're concerened about it Alan, can't just fit the factory manifold? Its a pretty easy sawp if its something you're going to lose sleep over. Great to see progress. Keep up the good work. JC |
Author: | Mearcat [ Thu Feb 02, 2012 10:55 am ] |
JC wrote: The stud is prone to coming away from the head ![]() http://austarletclub.com/index.php?/topic/9861-1996-starlet-life/?p=111432 |
Author: | Archangel007 [ Sun Mar 04, 2012 5:55 pm ] |
Mearcat wrote: My wife has given birth to our first child (Girl) 4 weeks early and with my wife in hospital for a while (1wk in, a few days out then another 1wk back in hospital
![]() A huge and personal congratulations for me and from all of us here on Ausmini with regards to the birth of your first child Alan. Welcome to fatherhood!!! I hope mum makes a full and complete recovery and everything goes very smoothly and your wife comes out soon. Good work mate and well done - congratulations again!! Cheers, Tricky P.S. - Good work on the Mini too and make hay while the sun shines mate!! |
Page 10 of 28 | All times are UTC + 10 hours |
