It is currently Fri Jul 18, 2025 11:47 am
PostPosted: Sat Jan 07, 2006 12:37 pm
As a longtime Fiat 124 Sport owner (which had cable clutch), all I can suggest is, buy a spare and carry it! :x
Cable clutches are all subject to Murphy's law. :wink:
PostPosted: Sat Jan 07, 2006 5:21 pm
[quote="
neato! looks way better than the pics I posted ;)[/quote]
Thanks ,the only mod i had to do to the body was drilling the hole for the cable to go through the rest is mounted onto my engine steady bracket which is removable.
PostPosted: Tue Jan 10, 2006 3:37 pm
I needed a longer pivot arm for the Subie clutch
also you will see I have relocated the whole pedal box:
(not finished yet, but it works :D )
PostPosted: Tue Jan 10, 2006 5:24 pm
that's really scary Mike! :wink:
PostPosted: Tue Jan 10, 2006 5:57 pm
The TIG
Are you guys sure it wouldn't just be easier to go hydraulic?
email - [email protected]
www.victoria-chiropractors.ca
PostPosted: Tue Jan 10, 2006 6:02 pm
awdmoke wrote:
I am a fan of trial & error engineering :oops:
Orangie in my case I would have nowhere to mount the clutch master cylinder (you should see the problems I had with the brake master :evil: )
Anyway, cable = lighter :D
PostPosted: Tue Jan 10, 2006 6:12 pm
The TIG
I do most of my engineering by trial and error too. I guess I am not familiar with your other modifications. I am still running the stock masters for the clutch and brakes in their stock locations. So all I had to do is make a bracket to mount the Mini slave cylinder and a modified lever arm to operate disengage the clutch and make a new hydro line to it.
I am always interested to see how others solve their problems it helps me learn too for future situations. Keep up the good work.
PostPosted: Tue Jan 10, 2006 7:17 pm
in my case, the clutch arm is at the front of the motor, over the front of the subframe, and comes upwards, so there's nowhere to put a slave cylinder beneath it... I could set up some kind of lever arrangement that would pull it up when the slave cylinder pushes it down, but that would probably give me as much hassle as setting up a cable...
