Dutchy's Vtec - Round Nose, standard length https://www.ausmini.com/forums/viewtopic.php?f=23&t=89636 |
Page 3 of 15 |
Author: | Dutchy1978 [ Fri Oct 02, 2015 10:10 pm ] |
Post subject: | Dutchy's Vtec - Round Nose, standard length |
A week off work to get stuck into it. Main frame done and engine mounted. Lower legs and rear cross brace with engine mount still to go in. |
Author: | Dutchy1978 [ Sun Oct 11, 2015 7:40 pm ] |
Post subject: | Re: Dutchy's Vtec - Round Nose, standard length |
Frame all welded up, engine wiring harness re-taped. Now working on the rear engine mount, lower control arm mounts and gear linkage. |
Author: | Hobson [ Sun Oct 11, 2015 8:30 pm ] |
Looking good |
Author: | Archangel007 [ Mon Oct 12, 2015 6:17 pm ] |
Yeah, nice!! |
Author: | Dutchy1978 [ Sat Oct 24, 2015 7:28 pm ] |
Part of the fun: engine in, engine out, engine in, engine out. This time to get the castor rod mounts tacked in, rear engine mount tacked together too. |
Author: | Phil 850 [ Sun Oct 25, 2015 6:36 am ] |
That's looking really cool. Is it just me, there is something about Honda engines that makes them "look the goods". |
Author: | ALPINE MOKE [ Sun Oct 25, 2015 7:12 am ] |
How do you change the oil filter, or do you intend to fit a remote one |
Author: | Hobson [ Mon Oct 26, 2015 9:45 am ] |
ALPINE MOKE wrote: How do you change the oil filter, or do you intend to fit a remote one With a great deal of difficulty. Do you plan on repainting the rocker cover? |
Author: | Dutchy1978 [ Tue Oct 27, 2015 6:09 am ] |
ALPINE MOKE wrote: How do you change the oil filter, or do you intend to fit a remote one It must be the photo. There is plenty of room to remove it. |
Author: | Dutchy1978 [ Tue Oct 27, 2015 6:11 am ] |
Hobson wrote: ALPINE MOKE wrote: How do you change the oil filter, or do you intend to fit a remote one With a great deal of difficulty. Do you plan on repainting the rocker cover? Yep, painting it red once everything is done. I have another one that I have stripped back that has "VTEC" and Honda on it still. Not sure which one I'll use yet. Branding or no branding.... |
Rear engine mount done. Lower control arm mounts done. |
Author: | Dutchy1978 [ Sun Nov 08, 2015 4:15 pm ] |
Back on 4 legs. Suspension geometry seems quite good by eye. |
Author: | Harley [ Sun Nov 08, 2015 6:11 pm ] |
Your rate of progress is incredible - and unfair! It'll be running by christmas! Great work! |
Author: | MiniMan_Alis [ Mon Nov 09, 2015 12:11 pm ] |
this is so fantastic, what are you doing for the rear mount or the torque mounts? it also looks like there is a bit or positive camber on the front. |
Author: | simon k [ Mon Nov 09, 2015 9:51 pm ] |
MiniMan_Alis wrote: it also looks like there is a bit or positive camber on the front. he's got plenty of adjustment there... |
Page 3 of 15 | All times are UTC + 10 hours |
