suzuki hayabusa GSX1300R fwd/rwd mini conversion https://www.ausmini.com/forums/viewtopic.php?f=23&t=13257 |
Page 1 of 2 |
Author: | inazuma_x [ Fri Nov 18, 2005 1:51 pm ] |
Post subject: | suzuki hayabusa GSX1300R fwd/rwd mini conversion |
how feasible is this? fwd would be preferable...but i couldnt find much on the web about this...does anyone know anything regarding this? |
Author: | minimetoy [ Fri Nov 18, 2005 1:56 pm ] |
How would you set up reverse ??? I would think the rest of it could be done with the usual headaches. Dan |
Author: | fuzzy-hair-man [ Fri Nov 18, 2005 1:58 pm ] |
They are areasonably common conversion in the UK there is a company there that does either Yamaha R1 or hyabusa or turbo hyabusa engined minis. I think the problem with bike engine conversions is getting a reverse but there are ways around it ie electric engine for reverse etc... http://www.zcars.org.uk/mini/mini-single.htm There was also quite a bit on the 16vmini or something similar forum in the UK Oops simultaneous posting reverse can also be done by a sort of second gearbox I think which would give you 5 reverses I guess ![]() |
Author: | inazuma_x [ Fri Nov 18, 2005 2:06 pm ] |
yeah initially i thought reverse would be the main problem...but have heard that getting a reverse gear for a bike engine isnt really that hard... i dont wanna pay like 20,000 pounds for the conversion...if it were possible i'd wanna do alot of it myself...as long as i dont have to cut the body up much...i can weld...and could probably work something out in terms of a front subframe with some engineering help from a REAL engineer...does anyone know anybody in AU who's done or has any experience in doing a hayabusa conversion? |
Author: | inazuma_x [ Fri Nov 18, 2005 2:09 pm ] |
WHOA! holy crap! Hyabusa Suzuki Mini with ? tank of fuel, carbon flip front, carbon boot lid, fully trimmed road use with all other fluids ready to drive: Weight 600 kilos Front Axle 290 kilos Rear Axle 310 kilos 0 to 60mph 3.5 seconds 100 to 0mph 4.9 seconds Top speed 125 mph BHP at Crank 180 bhp Power to weight ratio 300 bhp/tonne for ONLY 8000 pounds ![]() |
Author: | inazuma_x [ Fri Nov 18, 2005 2:25 pm ] |
thats it...i want one! ![]() http://www.zcars.org.uk/videos/winmedia/black.wmv |
Author: | JC [ Fri Nov 18, 2005 3:16 pm ] |
So you've seen the light then? Before you go and get all excited about doing it, consider that you would have two chances in hell of getting a rear-wheel driven mini registered in Oz. |
Author: | fuzzy-hair-man [ Fri Nov 18, 2005 3:27 pm ] |
striped 63 wrote: So you've seen the light then?
Before you go and get all excited about doing it, consider that you would have two chances in hell of getting a rear-wheel driven mini registered in Oz. I don't know that that lot make them but there are fwd bike engined minis about. |
Author: | awdmoke [ Fri Nov 18, 2005 3:39 pm ] |
Before you go and get all excited about doing it, consider that you would have two chances in hell of getting a rear-wheel driven mini registered in Oz. Can be done ![]() You will need to comply with the all the new rules, as my new engineer has advised me. Fortunately mine will now be a CBU Moke Utility - so many more loopholes with commercial vehicles ![]() |
Author: | inazuma_x [ Fri Nov 18, 2005 4:38 pm ] |
Before you go and get all excited about doing it, consider that you would have two chances in hell of getting a rear-wheel driven mini registered in Oz. perhaps yes perhaps no ![]() fwd one surely wouldnt require body chopping at all...the hayabusa engine would almost certainly fit in the engine bay of a mini...surely... |
Author: | Spaceboy [ Fri Nov 18, 2005 6:15 pm ] |
this mod requires extreme body modifications. but all minis should have come with one of those.. ****** unbelieveable. |
Author: | inazuma_x [ Fri Nov 18, 2005 6:37 pm ] |
extreme modification yes...but its just a hole in the back really ![]() i am more interested in a custom subframe to fit one to the front actually... |
Author: | h0nk [ Fri Nov 18, 2005 6:44 pm ] |
Has anyone done one in the front? I'm very interested in this conversion aswell.. either this or the honda b13b. |
Author: | meeni [ Fri Nov 18, 2005 6:55 pm ] |
u need a rather large bonnet extension on your car for a front one, someone in melbourne is doing one, i was told by the place i bought my seat from, as he is doing alot of business with them, so someone in aus is on the same boat as u |
Author: | fuzzy-hair-man [ Sat Nov 19, 2005 12:03 pm ] |
Here's some links about the bike engined minis hope it helps ![]() Ther are some good discussions of bike vrs car engines which might be helpful... http://www.16vminiclub.com/forums/viewtopic.php?t=1866&highlight=yamaha http://www.16vminiclub.com/forums/viewtopic.php?t=262&highlight=yamaha from http://www.16vminiclub.com/ |
