It is currently Sat Jun 28, 2025 10:05 pm
 Post subject: fuel hose
PostPosted: Mon Dec 05, 2005 10:46 pm
I picked up a packet of fuel hose, and when I got it home I realised that it did not say that it was for fuel injection, only for carburettors. well it didn't say that it wasn't for efi explicitly.... should I still use it, or should I take it back
$8.50 for 1m
PostPosted: Mon Dec 05, 2005 10:56 pm
Not worth the risk, i would take it back..also buy something with USA on it ;)
PostPosted: Mon Dec 05, 2005 11:44 pm
Use it for return/vent, buy some GOOD stuff for the supply lines :)
PostPosted: Tue Dec 06, 2005 9:01 am
You can also use it for the 'balancing pipe' and the breather pipes if you don't already have them.
JC
PostPosted: Tue Dec 06, 2005 12:16 pm
I bought a 5 metre roll of 7.5 mm EFI fuel hose from Coventry Auto for $30. Beats Supercrap at around $10 per m and is long enough to run the length of the car with no joins.
