It is currently Fri Jul 18, 2025 5:48 pm
 Post subject: vtec front cut $1400
PostPosted: Sat Feb 04, 2006 8:17 pm
found this on boostcruising
http://www.boostcruising.com/forums/ind ... pic=119153
PostPosted: Sat Feb 04, 2006 8:33 pm
Nice, cheap too...somebody buy it and put it in a mini...160HP 8)
PostPosted: Sat Feb 04, 2006 9:34 pm
Starlet turbos will eat it... without raising sweat! :lol:
PostPosted: Sat Feb 04, 2006 10:50 pm
With a few bolt on bits..but not stock :)
PostPosted: Sun Feb 05, 2006 5:56 am
Meh... Starlet Mini will be goooone, while the VTEC is waiting for the big cams to cut in... it's called t-o-r-q-u-e......
VTEC Minis in the states are getting a hard time at the drags from turbo A series still... :lol:
PostPosted: Sun Feb 05, 2006 8:09 am
Someting I hadn't really thought to much about was the weight, I was speaking with a guy yesterday who told me his car weighs 70 kilo's more with the Honda engine than it did with the A series :roll: thats a fair chunk to move of the line
PostPosted: Sun Feb 05, 2006 10:49 am
When that issue was raised in the past all the experts here said that the weight wouldn't rise. So much for experts.
Chris
Everything I like is either
PostPosted: Sun Feb 05, 2006 12:58 pm
Name and shame I say, name and shame!
PostPosted: Sun Feb 05, 2006 3:32 pm
well my conversion pushed my mini weight from 700kg to 740kg, not to bad considering that the brakes, wheels, seats tanks ect all add weight, not just the bigger motor putting out 6 TIMES the Hp, but hey im no expert :D
1974 Moke - 998cc
PostPosted: Sun Feb 05, 2006 5:38 pm
Is the ba16 a 1.6 L ..? Dont forget that there is a weight restriction when engineering an engine conversion. ORIGIONAL weight of car X 3 (if non turbo) and X 2.5 (if turbo) this will give you the max amout of cc the new engine can be
Life's a garden.... Dig It!
PostPosted: Sun Feb 05, 2006 7:28 pm
Yes B16A is 1.6 B18 1.8 etc..
You can run up to a 1.6 Turbo in a mini, or 2L NA...
Someone could buy this and turbo it. I'd keep it NA though and work it a bit 8)
I'm pretty sure in NSW we go of the weight of the car when engineered. So if you can make your car ~780Kg you can run a 2L turbo..could be wrong though, but that's the way i thought it was :idea:
PostPosted: Sun Feb 05, 2006 7:39 pm
In that Case josh, I'll just keep adding weight until i can run a 5 Litre !!
Nahh, i think its the ORIGINAL TARE Weight of the car - in FACTORY TRIM x2.5 Turbo or x3 N/a ...
J
PostPosted: Sun Feb 05, 2006 7:47 pm
I just remember the talks of putting sandbags in ROTA-MOKE... ;)
PostPosted: Mon Feb 06, 2006 8:47 am
the 4efte only weighs about 140kg...which is less than the a-series...alloy everything helps (cast iron block ofcourse...but everything else is lighter alloy)...the a-series is just a blob of iron basically :P not one of the lighter metals :P
Bling me up Scotty!
PostPosted: Mon Feb 06, 2006 9:37 am
Well my car climbed Gained 80kilos... after my build..
Thats with Full Fuel Tanks & all that water my car has now...
& BIG wheels & brakes... everything adds up not just motor..
Hmmm whats the arguement anyway... I am sure we are all better off!
Baracade
