It is currently Fri Jul 18, 2025 1:44 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2, 3  Next
PostPosted: Tue Feb 07, 2006 10:24 pm
Well all lights work, bonnets on etc. Took it for a spin around the block (with permit) 8) 8) :D :D . Off to Dyno tomorrow morning will post up sheet etc when I get the results. Fingers crossed no issues... 8)
PostPosted: Tue Feb 07, 2006 10:45 pm
Good luck Matt. Though I had it pointed out to me the other day 'luck' is opportunity meeting preparation. This build is a testimant to your preparation and lets hope we see plenty of opportunity.
JC
PostPosted: Wed Feb 08, 2006 8:22 am
Goodluck mate, hope it all goes well!
PostPosted: Wed Feb 08, 2006 12:23 pm
Good luck Matt, I hope you get a good result for all the hard work and effort that you have put in.
Dan
PostPosted: Wed Feb 08, 2006 1:04 pm
i really cant wait to see what the result is...so exciting! a new mini is born!
Bling me up Scotty!
PostPosted: Wed Feb 08, 2006 1:08 pm
Well guys Dyno has been done and very encouraging reports on the engine :D but horsepower wasn't so encouraging :cry: . Basically generated about 106hp. But he said that was all down to the turbo as it was only generating a max of 7psi. So it looks like I wll be making that manifold and sourcing a t25 tout suite. Still as long as the engine is sound that was my main concern. The rest I can work on...Now for the inspection and test...
PostPosted: Wed Feb 08, 2006 1:18 pm
yeah t25 is the go IMO...did you just stick with stock wastegate n stuff? 106 is still pretty good :) better than almost any a-series out there...
Bling me up Scotty!
PostPosted: Wed Feb 08, 2006 1:20 pm
matt did he say why the turbo was only running 7psi??
A few things to check would be hi-lo button is in the high position, if you have disconnected the switch which i think you have it will always run on low boost around 6-7psi.
If you have not got the swich hooked up, have you got the air lines off the wastgate actuator going to the little boost control solenoid?
If so just disconnect them and run a bleed valve between the wastgate actuator and the turbo.
1974 Moke - 998cc
PostPosted: Wed Feb 08, 2006 1:26 pm
So, 106 atw? That's a GREAT result. Onwards and upwards from here!!!
PostPosted: Wed Feb 08, 2006 1:33 pm
You've got to be happy with anything over 100 at that boost :D
Looks like we have a winner:
minimetoy wrote:
I'll put $1 on 107hp in standard trim.
Dan
PostPosted: Wed Feb 08, 2006 1:47 pm
Dan
i was actually gonna say 106...but thought that was too low :(
Bling me up Scotty!
PostPosted: Wed Feb 08, 2006 2:10 pm
Thanks guys yeah I am real happy as it is bog standard. And as Brad, Dean et al have demonstrated this is only the beginning as far tuning and performance are concerned. And I very sure this was on low boost so I am sure the 10Psi would probably have got her into the teens for power.
Brad I will have a look tonight at the boost switch, thanks for the heads up. Yeah I think it is almost a definite that I haven't hooked the switch up.
More news as it occurs. Testing is on Monday unless the engineer drops a bombshell tonight.
Matt
PostPosted: Wed Feb 08, 2006 2:53 pm
Well according to the Larry Emder school of thought I was closest with 100hp.
PostPosted: Wed Feb 08, 2006 3:11 pm
hahaha...this isnt the price is right JC ;)
Bling me up Scotty!
PostPosted: Wed Feb 08, 2006 7:40 pm
Congrats Matt, It sounds like all the hardwork has paid off.
I am sure over the next few months when you start fiddling the HP's will go up.
Dan
