Blackrz Update https://www.ausmini.com/forums/viewtopic.php?f=23&t=17194 |
Author: | BLACKRZ_667 [ Wed Mar 15, 2006 3:13 pm ] |
Post subject: | Blackrz Update |
Ok well the whole Starlet GT mini idea has gone ![]() ![]() I was just wondering if any one has done this conversion be fore and yes i have Googled it and have come up with a few but nothing that i can find that would suit my budget ![]() ![]() cheers guys |
Author: | inazuma_x [ Wed Mar 15, 2006 3:15 pm ] |
Post subject: | Re: Blackrz Update |
BLACKRZ_667 wrote: Ok well the whole Starlet GT mini idea has gone
![]() ![]() I was just wondering if any one has done this conversion be fore and yes i have Googled it and have come up with a few but nothing that i can find that would suit my budget ![]() ![]() cheers guys 4efte would be good ![]() |
Author: | fuzzy-hair-man [ Wed Mar 15, 2006 3:16 pm ] |
Well twini minis put mini engines in the back to drive the rear wheels.... Uses a modified front subframe. and just use the mini engine. That's iff al you want is a rear wheel drive mini |
Author: | BLACKRZ_667 [ Wed Mar 15, 2006 4:12 pm ] |
Im not all for the Rear mounted engine a mate said that i could use a VW Bug engine but im not to sure ![]() |
Author: | inazuma_x [ Wed Mar 15, 2006 4:15 pm ] |
BLACKRZ_667 wrote: Im not all for the Rear mounted engine a mate said that i could use a VW Bug engine but im not to sure
![]() there was a rwd starlet in the UK...would be pretty hard to get i would think...mid-engine would be pretty mad ![]() |
Author: | awdmoke [ Wed Mar 15, 2006 4:24 pm ] |
Most longitudinally mounted 4cyl engines will be too long even for a clubby bonnet. Being a flat-4, the subaru might fit.Otherwise go rotary! Oh, and there is no RWD setup for subies - only FWD/AWD/4WD. Just get an AWD or old 4WD box & don't use the front outputs. |
Author: | fuzzy-hair-man [ Wed Mar 15, 2006 4:25 pm ] |
![]() Why a tail shaft? If it isn't a transverse mounted engine you will probably have to cut the begezzus outta your floor pan to get the gearbox in and if it is a transverse engine it's probably a front wheel drive anyway ![]() Someone PMed me after a dead Datto 1200 ute to chop up and put a mini body on ![]() We wanted it for spares ![]() |
