Roundnose conversion ? https://www.ausmini.com/forums/viewtopic.php?f=23&t=17388 |
Page 1 of 4 |
Author: | _666_ [ Tue Mar 21, 2006 12:03 pm ] |
Post subject: | Roundnose conversion ? |
just a querie bout roundnose engine conversions are theyre any engines that can be used that dont involve body work (not including subframes) being altered? |
Author: | inazuma_x [ Tue Mar 21, 2006 12:04 pm ] |
Post subject: | Re: Roundnose conversion ? |
_666_ wrote: just a querie bout roundnose engine conversions are theyre any engines that can be used that dont involve body work (not including subframes) being altered?
only ones that arent all that wonderful...this applies to clubmans too i believe...by body work we are talking not even the inside walls of the engine bay i am assuming? |
Author: | cush [ Tue Mar 21, 2006 12:04 pm ] |
the swift/cultus gti? |
Author: | inazuma_x [ Tue Mar 21, 2006 12:05 pm ] |
cush wrote: the swift/cultus gti?
still need to cut the crap out of the engine bay walls... |
Author: | _666_ [ Tue Mar 21, 2006 12:09 pm ] |
well yeah.. i guess some engine bay cuting wouldnt be too bad.... but if its avoidable... |
Author: | inazuma_x [ Tue Mar 21, 2006 12:12 pm ] |
_666_ wrote: well yeah.. i guess some engine bay cuting wouldnt be too bad.... but if its avoidable...
you could just convert to an a-series ![]() |
Author: | _666_ [ Tue Mar 21, 2006 12:15 pm ] |
and erm...that means ? ... im looking into conversions that dont involve too much effort (although its still gonne just as much as any conversion) becuase its a heck of a lot easier than working out power steering/ Airconditioning on its own... as well as the fact the a/c costs like $880.. it works out cheaper and something around 1.3/l would be good.. just enough to give commies a little scare.. |
Author: | inazuma_x [ Tue Mar 21, 2006 12:41 pm ] |
_666_ wrote: and erm...that means ? ... i was kidding _666_ wrote: im looking into conversions that dont involve too much effort (although its still gonne just as much as any conversion) becuase its a heck of a lot easier than working out power steering/ Airconditioning on its own... as well as the fact the a/c costs like $880.. it works out cheaper and something around 1.3/l would be good.. just enough to give commies a little scare..
i dont know of any modern engines that are equal in size to or smaller than an a-series (maybe there are some 3cyl ones kicking around that are)...the a-series gb is in its sump...and so that saves ALOT of space... |
Author: | minstar [ Tue Mar 21, 2006 2:28 pm ] |
Maybe a 3cyl Daihatsu that's pretty small even with the gearbox on the side and the turbo ones make about 100hp fully tricked up...? I wish someone made a V4 FWD engine that would cut down the size a bit. |
Author: | inazuma_x [ Tue Mar 21, 2006 2:30 pm ] |
minstar wrote: Maybe a 3cyl Daihatsu that's pretty small even with the gearbox on the side and the turbo ones make about 100hp fully tricked up...? I wish someone made a V4 FWD engine that would cut down the size a bit.
wishin wont make it happen ![]() |
Author: | cush [ Tue Mar 21, 2006 2:43 pm ] |
early ford capri's, corsairs, saabs and lancias had v4's |
Author: | awdmoke [ Tue Mar 21, 2006 2:45 pm ] |
Maybe use a Suzuki Vitara V6? ![]() Can't think of a smaller readily available V6 |
Author: | inazuma_x [ Tue Mar 21, 2006 2:52 pm ] |
awdmoke wrote: Maybe use a Suzuki Vitara V6?
![]() Can't think of a smaller readily available V6 isnt it nth/sth? i woulda thought the 1.8L mazda 30x motor woulda been yer best bet for a v6 conversion... as for v4...why bother ![]() ![]() |
Author: | _666_ [ Tue Mar 21, 2006 5:08 pm ] |
hmm ok... whats the stock horse power of an 1100 mini ? |
Author: | inazuma_x [ Tue Mar 21, 2006 5:24 pm ] |
_666_ wrote: hmm ok... whats the stock horse power of an 1100 mini ?
50ish at the crank i believe... |
Page 1 of 4 | All times are UTC + 10 hours |
