It is currently Fri Jun 27, 2025 9:41 am
 Post subject: Brake master cylinder?
PostPosted: Sun Sep 24, 2006 9:04 pm
Hi guys. I reckon none of you will have come up against this, but do you think I could use a twin circuit Mini brake master with the starlet brakes un boosted?
Have engineers insistes on boosters for anyone?
Madmorrie
PostPosted: Sun Sep 24, 2006 9:15 pm
Have to go booster in NSW as far as i know..
PostPosted: Sun Sep 24, 2006 9:51 pm
Mandatory in QLD
PostPosted: Mon Sep 25, 2006 12:15 pm
I have the twin MC and the metro brakes and no booster, never been a problem for me and I had to go over the pits 3 times. They questioned it but I well and truly passed the brake strength test. I guess we could start that argument about whether boosters only make pedal effort easier but don't actually increase the brake clamping pressure at the calliper... :lol:
Matt
PostPosted: Mon Sep 25, 2006 1:41 pm
Matt,
Please measure both thighs and advise.
Dan
PostPosted: Mon Sep 25, 2006 11:04 pm
As I am a left foot "Orthodox" braker my left thigh is bigger by 6 inches, but now I walk funny... :)
PostPosted: Tue Sep 26, 2006 11:17 am
i have mini twin circuit camira disc and callippers no booster is needed to pass in nsw
PostPosted: Tue Sep 26, 2006 2:57 pm
I agree with that.
Dan
PostPosted: Tue Sep 26, 2006 3:04 pm
Are you going to run a booster dan? I'm considering not fitting my booster now...
PostPosted: Tue Sep 26, 2006 11:28 pm
hey question for you about those brakes Josh - have the suppliers advised you on what bore master cylinder to use? just out of interest...
PostPosted: Wed Sep 27, 2006 8:32 am
They were designed to work off a standard mini master
PostPosted: Wed Sep 27, 2006 8:44 am
Josh,
I won't be installing a booster.I don't see the point in doing so at this stage. I have finished the brakes and they feel good to me, they are slightly hard but i was expecting that.
My clutch is very hard, I am a bit concerned about it because i think its going to grab very quick. Will see how it goes on its maiden flight.
Dan
PostPosted: Wed Sep 27, 2006 8:46 am
How long you got to go before then Dan?
I should be up for measuring my shafts next week :)
PostPosted: Wed Sep 27, 2006 9:54 am
Josh,
I have to stop for the next two weeks as we have visitors from overseas coming.
But then i'm straight into wiring it up and as soon as that is done i can start her.
Brakes, clutch, accelerator, fuel lines all done. I have to fit the oil filter, i am currently waiting for the union to be sent from toyota in japan to be able to finish that of and run the line for the oil pressure gauge. Final item is the air filter and box but i can easily start it without if required.
Dan.
