Im thinking about installing one of these https://www.ausmini.com/forums/viewtopic.php?f=23&t=32879 |
Author: | gzeVan [ Fri Jun 15, 2007 8:42 am ] |
Post subject: | Im thinking about installing one of these |
what do you guys think its either this or a F6a/K6a also this one will cost me far less from a mates wrecking yard ![]() its a cg13de |
Author: | cush [ Fri Jun 15, 2007 8:46 am ] |
the nissan march engine? 58 kW... not bad... ![]() a fairly recent make too.. |
Author: | bnicho [ Fri Jun 15, 2007 12:45 pm ] |
It's a swap I've considered for a while. Compact litlle 1275cc motor and there is a 930cc supercharged and turbo variant available too. |
Author: | 13secmini [ Fri Jun 15, 2007 5:44 pm ] |
yeh they seem to be a tuff little motor. I have not had a chance to measure one up but the pics i've seen over the net they look pretty compact. Put a nice turbo combo on it and i can see it matching a 4efte. Looks like a mini sr20 with that head too haha. |
Author: | gzeVan [ Fri Jun 15, 2007 6:26 pm ] |
If there is room i will turbo it, your right brad it does look like a baby sr it even has chain driven camshafts under that cover |
Author: | bnicho [ Fri Jun 15, 2007 6:57 pm ] |
There's a mostly complete Micra with minor front end damage in the local wreckers. It's been temping me for months. ![]() |
Author: | gzeVan [ Fri Jun 15, 2007 8:40 pm ] |
hey brett, they seem like a decent swap but i havent seen a gearbox yet as this ones an auto upside: ![]() Down side: ![]() does anyone know if they are rod or cable shift + hyrdo or cable clutch |
Author: | bnicho [ Fri Jun 15, 2007 8:58 pm ] |
gzeVan wrote: hey brett, they seem like a decent swap but i havent seen a gearbox yet as this ones an auto
upside: ![]() Down side: ![]() does anyone know if they are rod or cable shift + hyrdo or cable clutch The one in the local yard is on top of another car. I can go and check out the gear linkage and clutch if you like. Remote mounting the oil filter may be an option. Cheers, Cheers, |
Author: | miniboy1962 [ Sat Jun 16, 2007 3:24 am ] |
What does it matter that the oil filter is on the other side? Doesn't tjat mean that it can be hidden along with the starter motor, surely the oil filter wont poke out that much.... |
Author: | gzeVan [ Sat Jun 16, 2007 10:02 am ] |
it would be a pain in the bum to change |
Author: | cush [ Sat Jun 16, 2007 10:10 am ] |
13secmini wrote: Looks like a mini sr20 with that head too haha.
i thought that, too ![]() |
Author: | gzeVan [ Tue Jun 19, 2007 7:25 pm ] |
we tried a n12 pulsar gearbox today and would you belive it fits ![]() ![]() also a n16 flywheel fitted too ![]() the whole engine and box measured up at 74cm long which will fit nice cheers Paul |
Author: | cush [ Tue Jun 19, 2007 9:28 pm ] |
nissan were good at that... so how much was the gearbox? |
Author: | gzeVan [ Tue Jun 19, 2007 10:45 pm ] |
Quote: so how much was the gearbox?
$150 |
