16V T/C / Honda on 1275 https://www.ausmini.com/forums/viewtopic.php?f=23&t=50923 |
Author: | david rosenthal [ Fri Mar 06, 2009 2:54 pm ] |
Post subject: | 16V T/C / Honda on 1275 |
http://www.youtube.com/watch?v=Wp3QUpCDbr0 Here is the latest addition. 1275 bored .020" oversize, 10:1 comp. It's a bit lumpy at idle but pulls revs quite well. This eng is going into a customer's worked road car. 4 wheel discs, fully adjustable coil over suspension, beefed up gearbox with LSD. These heads fit the 1275 as well as the small bore engs with minimal re-boring. This engine has all magnesium alloy pullys and still runs the std bike carbys. I have redesigned the adapter plate and it now fits both types of engines apart from thickness required for comp. ratio. A few things to change for oil cooler set-up and filter system for head, and rev limiter, but these will be done when installed. This is the video of the 1100 engine with .040" same set up for carbies etc. this engine is for sale[see for sale section] http://www.youtube.com/watch?v=sFOgK0xdi0w |
Author: | mini-dunger [ Fri Mar 06, 2009 4:15 pm ] |
that 1275 sounds tough, it must have a bunch of overlap. Do the Honda's have a more aggressive profile than the BMW heads? |
Author: | TheMiniMan [ Fri Mar 06, 2009 9:08 pm ] |
David,,, you need the evil laughter at the end of it like mine ![]() well done young fella ![]() i`ve got the Yamaha 20v on the go now too ![]() |
Author: | david rosenthal [ Fri Mar 06, 2009 9:37 pm ] |
mini-dunger wrote: Do the Honda's have a more aggressive profile than the BMW heads? Farked if I know, I just kept adjusting the cams, gave it more fuel and tried it. It kept idling and reved with no hesitation. I might put the eng degree disc on and see what it is. I thought that it would cough and splutter sooner or later but it didn't. Hey Matt I hope you are going to stick that yammy head on one of those little strokers you are building. A little puffer as well and LOOK OUT. That would be a awsome engine. Those yammys are a magnificent piece of technology. As for the little laugh, I had been working on it for 36hrs straight, and it was one of those jobs where ever little thing would give you the sh!!!!!ts. Even when I started to film it when I first started it I forgot to turn the fuel on, ![]() ![]() ![]() ![]() |
Author: | TheMiniMan [ Fri Mar 06, 2009 9:48 pm ] |
hee hee,,, yeah i`m with ya mate ![]() at least you can actually see something in your vid,,, i really do need to hook up my hemet cam,,, i use it for Down Hill Mountasin bike racing & have been using it to video some of the Bimmer conversion builds,,, just didn`t even think about it when we videoed the small bore for some strange (Jim beam) reason ![]() |
Author: | david rosenthal [ Fri Mar 06, 2009 10:12 pm ] |
That idea of a helmet camera is BRILLIANT!!!!!!!. It's a bitch when you first run these things and you need more arms than a octapuss, checking everthing at once and listening for every little noise. When it ran out of fuel I checked every thing except the obvious ![]() Any way sit it in a corner and go on with the rest of the car, after I have a massive clean up. the workshop looks like a chinese brothel after a heap of drunken sailers have been there for a week. Maybe I should get an apprentice, the missus does not know how to use a broom and anyway she has to work to support me ![]() |
Author: | TheMiniMan [ Fri Mar 06, 2009 10:37 pm ] |
OZ-Spy have great little CCD cubes,,, colour & sound,,, really good things, $200,,, we mount these under our visor on the helmets (out of the way for if,,, no sorry "When" we crash ![]() so i use a JNC mulit media player/recorer to plug it into, shove it in my pocket & off we go,,, has good sized screen, button lock outs so you don`t bump them on/off when you don`t want to, & only about $400 there are quite a few Down hill mountain bike videos with my helmet cam footage involved ![]() But there are water proof pencil type cameras avaliable now too,,, with battery & memory card already in them, strap it on & have a play (sounds kinky i know ![]() ![]() |
Author: | david rosenthal [ Fri Mar 06, 2009 10:51 pm ] |
It's amazing the cameras that they have now. My daughter's b/f just bought one of those cameras on a thin flexabile wand. pull a spark plug out ,shove it it the hole and look around. you can look all around the inside of a cylinder, check the v/v's out. This modern technology is unreal. I think back when I was his age and I was using a log book to do mathamatical calculations |
Author: | TheMiniMan [ Fri Mar 06, 2009 11:19 pm ] |
Not only that, but you can take a copy of that & send it all over the world in a few minutes for millions of people to see when i was a kid,,, we had wooden fruit crates & old lawn mower wheels , a coup,e of bits of fence post & a piece of string & we made billy carts,,, kids these days have the whole world to play with i wanna be a kid again ![]() |
Author: | david rosenthal [ Fri Mar 06, 2009 11:57 pm ] |
Not me mate. I have got 4 daughters and I would not go thru adolesence again. I got in to so much trouble then and how am I still alive when I think back on it. If i did it again I would definately come unstuck. more lives than a cat ![]() |
Author: | mini-dunger [ Sat Mar 07, 2009 11:13 am ] |
dave, I will come clean your shed if you show me some stuff. |
Author: | david rosenthal [ Sat Mar 07, 2009 1:44 pm ] |
mini-dunger wrote: dave, I will come clean your shed if you show me some stuff.
you are more than welcome to come up at anytime, just give me a quick ring on 0429088100 just to make sure i will be there. you do not have to sweep floors. doing that gives me time to think |
