It is currently Thu Jun 26, 2025 1:32 pm
PostPosted: Mon May 11, 2009 1:48 am
Hi everyone,
Currently my mini are bare shell.
Would you guys recommend me with the good soundener materials that will able to
reduce heat as well as sound proof.
Did a search on ebay and google
This is quite cheap compare with Sound Off and Dynamat product.
http://cgi.ebay.com.au/HEAT-PROOF-BODY-DEADENER-SOUND-PROOFING-ALUM-SHEET_W0QQitemZ360152221014QQcmdZViewItemQQptZAU_Car_Parts_Accessories?hash=item360152221014&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A1%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
Dynamat
Dynamat Sound Deadener on ebay
Sound Off
http://www.soundoff.com.au/pricelist.html
Aerpro Product
Hopefully you guys can guide me to some good products and aren't too expensive.
Thank you
I'm from Melbourne
PostPosted: Mon May 11, 2009 4:10 pm
I used to work in car audio, and I will definetly be using Dynamat Extreme on my mini. Its so much nicer than many other products, and it works (although I've neved used it for heat reduction).
PostPosted: Mon May 11, 2009 4:20 pm
ive just purchased 30kgs of option audio sound deadener... its exactly the same as dyna matt apparently even made in the same factory... but much cheaper... maybe look into that... not sure were my mate got mine from as he works in a resto workshop... yet to put it in my car but they use it all the time and recommend it... hope this helps
PostPosted: Mon May 11, 2009 8:51 pm
I got one of those bulk packs off ebay and have decked out from the seat rail/box bit forward and still have a metric tonne left. I am going to do the back of the van and a strip on the roof and if any is left over maybe a nice shiny vest that doubles as a back waxer...
D
PostPosted: Tue May 12, 2009 9:43 am
Hi Bigtimmyp
as you mentioned the product exactly same as dyna matt.
Where can I find it?
Also you guys think the price of dyna matt on ebay will be cheaper from the retailer stores? I haven't got a chance to see where I can get them from stores.
Does the dyna matt extreme are able to apply on anywhere on the car, even firewall and bonnet?
Thanks for all the replys.
PostPosted: Tue May 12, 2009 11:59 am
I had a look at audio places and it was about 299 instead of 219 for the bulk pack.
I don't know about firewall inside the engine bay but mine is all over the firewall inside the compartment.
PostPosted: Tue May 12, 2009 12:17 pm
hey Floss
would you able to give me the link of your products on ebay please.
Let me have a check it out.
cheers mate
PostPosted: Tue May 12, 2009 1:20 pm
10 - 4 roger that.
I got it from this dude
http://myworld.ebay.com.au/quicksmarttechnology
PostPosted: Tue May 12, 2009 5:50 pm
sorry i dont know were i got mine from... ill try and find out for you tomoro :) id say you can put it on your bonet and fire wall if u wanted too... its got the silver heat reflective stuff on the back so i dont see why not?!?
i plan to put it on my bonet eventually
PostPosted: Tue May 12, 2009 11:07 pm
thanks bigtimmyp
PostPosted: Wed May 13, 2009 1:42 pm
I got a pack of Dynamat Extreme from Knox Auto Carpets, only cost me $220 and I could buy it over the counter. They charge an extra $25 for delivery. At that price there was no need to frig about on eBay.
See: http://www.knoxautocarpets.com.au/moulded_carpets.htm - it's right down the bottom of "Additonal items".
66 Deluxe, 07 Cooper
PostPosted: Thu May 14, 2009 1:03 am
Thanks Paul
That's good recommendation.
PostPosted: Fri May 15, 2009 7:12 am
Thats a good price!
I went to a few audio shops near me and they all charge like wounded bulls. Maybe they thought that they saw me coming and I looked dense or something :) :)
PostPosted: Sat May 16, 2009 8:59 pm
Does one pack enough for the whole car?
I might check it out next week than.
PostPosted: Fri May 22, 2009 7:43 am
well it depends on what you are doing I guess. it gives you 36 square feet. I think it will do my inner cabin floor, firewall, strip down the roof and still have some left over but cant be certain till its done. Any left over I will maybe double up on the firewall.
ohh and as pooee said to me. Make sure you get 9 sheets as some guys will take one sheet out of the box and sell it cheap but then every eight kits they sell they get a free kit.
D
