1990 Toyota corolla 4AFE auto
https://www.ausmini.com/forums/viewtopic.php?f=23&t=65150
Author:  Kennomini [ Fri Aug 20, 2010 6:19 pm ]
Post subject:  1990 Toyota corolla 4AFE auto
Is it any good for a conversion or what?
Author:  TheMiniMan [ Fri Aug 20, 2010 6:23 pm ]
no,,, if it`s not got 5 million HP,,,, big gobs of torque,,,, is far lighter,,, bolts straight in,,, & costs almost nothing
then don`t do it
Author:  blue_deluxe [ Fri Aug 20, 2010 10:37 pm ]
It depends, if your converting it into a 1990 corolla with a stuffed engine itd be fantastic.
In a mini the auto on toyotas is quite large, so bulkhead mods would need to be done.
Author:  simon k [ Fri Aug 20, 2010 11:57 pm ]
jeez - I moved that other thread into other makes because I thought you'd put it in here by mistake and you were just asking if it was OK for a runabout.... I didn't expect anyone would want to put one of those in a mini, yukko
Author:  Kennomini [ Sat Aug 21, 2010 12:22 am ]
Ha I thought I had posted it but wasn't sure when I couldn't find it :? I just thought because it's from the Toyota 4A... family it may have been worth a look. I wasn't to sure about the auto either, had a feeling it would be too big.
Author:  cazmo [ Sun Aug 22, 2010 1:00 am ]
A 4AFE is just a more fuel efficient version of the 4AGE. Similar size, interchangeable block and gearbox.
If you were going to go to the effort of using a 4a engine, then you would be much better off using the 4AGE.
