Coming to a shaker bonnet near you https://www.ausmini.com/forums/viewtopic.php?f=23&t=67415 |
Page 1 of 3 |
Author: | Angusdog [ Thu Dec 02, 2010 8:17 am ] |
Post subject: | Coming to a shaker bonnet near you |
V4 version of Corvette small block could be ideal for a mini. Compact, car based so no probs with oil surge, just run a shaft back to a transaxle, Bob's your mother's brother. ![]() |
Author: | MiniDna [ Thu Dec 02, 2010 9:04 am ] |
I did check their website. It does look really nice. Would make nice alternative engine for the Mini IMO. Some info from the website: Weight of the BMW engine as provided by BMW is 102.6 kilograms or 226.19 pounds. I expect you’ll hear praise for how light the BMW engine is. The weight of the entire KMV4 powertrain, including gearbox, is designed to be under 200 pounds, it's not yet final but it looks to be easily on target. Advantage KMV4. Engine width: BMW: 560mm or 22.047 inches, KMV4: 492mm or 19.37 inches. Remember, the BMW engine is described on their website as compact. Yes, that’s in comparison to other 6 cylinder engines but you will also likely hear comments praising BMW for their achievement in building a relatively narrow engine. Advantage KMV4. Torque: BMW 175 Nm or 129 foot pounds, KMV4 162 Nm or 119 foot pounds. Advantage BMW. Now, this is interesting. All of the horsepower figures you've seen so far on the KMV4 have been target figures and listed on the website as 140 minimum, however, as the video clearly shows, the KMV4 has been on the dynamometer. So what did The Kneeslider find out for you? BMW 160 horsepower, KMV4 161 horsepower. The BMW 6 makes a little less horsepower than the KMV4 and it has 6 cylinders, dual overhead cams and 4 valves per cylinder. The pushrod, 2 valve V4 does more. Advantage KMV4. So, just to recap, compared to the BMW, for the same displacement, the KMV4 has fewer cylinders, fewer moving parts, it's narrower, lighter and makes more power. Cool |
Author: | awdmoke [ Thu Dec 02, 2010 9:14 am ] |
VSBC = Very Small Block Chev? I haven't heard a V4 for years, so I'd forgotten what they sound like. Would be even better with a blower on it. |
Author: | Angusdog [ Thu Dec 02, 2010 4:18 pm ] |
![]() Yum. (Just imagine fewer trumpets). |
Author: | blue_deluxe [ Thu Dec 02, 2010 5:35 pm ] |
It could be good if run it east west. Any idea what bellhousing it would fit? |
Author: | JC [ Thu Dec 02, 2010 6:21 pm ] |
blue_deluxe wrote: It could be good if run it east west.
Any idea what bellhousing it would fit? Custom per application I reckon. |
Author: | Mearcat [ Thu Dec 02, 2010 7:45 pm ] |
I just did a search on youtube to see what a V4 sounds like... I LIKE!! ![]() ![]() |
Author: | Morris 1100 [ Thu Dec 02, 2010 7:56 pm ] |
Mearcat wrote: I just did a search on youtube to see what a V4 sounds like... I LIKE!!
![]() ![]() I had an F100 with a Clevo. On a rainy day I learned what a V4 sounded like. ![]() When I broke a camshaft I learned what a big V2 sounded like! ![]() |
Author: | '77 clubby van [ Fri Dec 03, 2010 8:51 am ] |
It would be cool to have the sound, but to tell you the truth those figues don't impress me that much. ![]() 161 hp @ 7800 & 162 Nm @ 4500 for an expensive one off engine which sounds really cool and no one else has.... Vs 133 hp @ 6400 & 157 Nm @ 4800 for a cheap, standard 4efte which is easily upgradable with cheap parts with toyota reliability. It does sound good though! ![]() |
Author: | Timbo [ Fri Dec 03, 2010 9:16 am ] |
If it was short enough to fit transversely with an end on gearbox and not require any body mods it would be sweet, it looks pretty wide though. Tim |
Author: | Morris 1100 [ Fri Dec 03, 2010 3:33 pm ] |
The yanks have been making a V4 based on the small block chev for about 20 years (or more) for speedway cars. ![]() They give 300hp quite easily. |
Author: | mini-dunger [ Fri Dec 03, 2010 8:11 pm ] |
there was a guy in a street machine mag recently who had chopped 6 cylinders of a cleavo and made a v2 chev have been doing it with v6's for ages |
Author: | drmini in aust [ Fri Dec 03, 2010 9:18 pm ] |
Morris 1100 wrote: The yanks have been making a V4 based on the small block chev for about 20 years (or more) for speedway cars.
![]() They give 300hp quite easily. Looks simple and reliable. Big reliable bits and pushrods. No DOHC complexity, or hairdryers either. ![]() |
Author: | Morris 1100 [ Fri Dec 03, 2010 9:25 pm ] |
drmini in aust wrote: Morris 1100 wrote: The yanks have been making a V4 based on the small block chev for about 20 years (or more) for speedway cars. ![]() They give 300hp quite easily. Looks simple and reliable. Big reliable bits and pushrods. No DOHC complexity, or hairdryers either. ![]() I looked on the net and found that they can get 650 on alcohol. ![]() But like most V4s they vibrate badly. But these vibrate more than most. ![]() |
Author: | '77 clubby van [ Mon Dec 06, 2010 7:31 am ] |
drmini in aust wrote: .......... No DOHC complexity, or hairdryers either.
![]() You could leave the A series in and have that! ![]() |
Page 1 of 3 | All times are UTC + 10 hours |
