It is currently Thu Jul 10, 2025 12:41 am
 Post subject: 4efte auto
PostPosted: Wed Sep 19, 2012 9:38 pm
can anyone tell me if the 4efte auto will fit in a round nose mini,or is the trans to big.
mini regards
peter d.
1st victorian road registered vtec mini.
PostPosted: Wed Sep 19, 2012 9:45 pm
Nope, won't fit.
Roundnose or clubman matters not. if you could figure out a way where the passenger side suspension tower and lower arm didn't need to be there you might be able to make it work...
PostPosted: Wed Sep 19, 2012 9:57 pm
JC wrote:
Nope, won't fit.
thanks for the reply.
mini regards
peter d.
PostPosted: Wed Sep 19, 2012 10:19 pm
It's the big lump on the high right side of this photos that's the problem.
PostPosted: Thu Sep 20, 2012 10:20 pm
Simple, mount the engine and box North-South and line the drive shafts up in the center tunnel and have a diff in the front and the rear. 160-200bhp ATW and AWD :twisted:
PostPosted: Thu Sep 20, 2012 10:51 pm
But auto................. (•_• )
PostPosted: Fri Sep 21, 2012 7:40 am
Simple.
Do keep us up to date with what you find out though Peter. I was always found of an auto converted mini.
Actually Peter if you eyeball one and can offer it up to a mini frame I wonder if you could cut away the tower, maintain the mount point on of the top arm and just run some coilovers in the front.
PostPosted: Fri Sep 21, 2012 11:13 am
And where would you get 1:1 ratio diffs from???
PostPosted: Fri Sep 21, 2012 11:20 am
That's the only flaw you can find in that sentence? :lol:
PostPosted: Fri Sep 21, 2012 12:01 pm
JC wrote:
Simple.
not sure if u could tilt the motor forward a bit ? and who knows unless we try.
PostPosted: Fri Sep 21, 2012 12:20 pm
Just build new suspension pickups for it, could very simply make an a arm setup that mounts elsewhere
PostPosted: Fri Sep 21, 2012 3:28 pm
I reckon look for a more compact auto.
PostPosted: Fri Sep 21, 2012 3:42 pm
Nope, but the most obvious!! :wink:
