It is currently Fri Jul 11, 2025 2:20 am
Post new topic Reply to topic  [ 75 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: g13b turbo clubby
PostPosted: Fri May 15, 2009 4:05 pm
hey guys
just thought i would let everyone know about my clubman project. as heading says a swift gti motor with a small turbo setup (8psi).
http://www.redlinegti.com/forum/gallery ... um_id=1407
just to emphasize i am not the builder, red89gti (jason) has done some work on my swift gti previously and talks were underway about putting his gti turbo setup into a mini...
some online searching, a 78 clubman and a donor swift gti later and here we are.
ive driven this turbo setup in red89gti's swift':shock:' and with the mini weighing about 150kg's less, needless to say im pretty keen
also cramming into the mini...
half cage
swift adjustable column
custom made inlet manifold
top mount intercooler
remote brake booster
7.5" front disc setup
full 2 1/4" exhaust, hi flow cat etc...
swift gti tank
2 all black autotechnica reclinable seats
defi boost, oil temp and pressure guages
pioneer head unit and 6x9s
mat black ultralight 13x7s
hopefully up and running soon
PostPosted: Fri May 15, 2009 4:14 pm
Some nice work there 8)
You will sure need some good rubber to put that power to the ground, and I'm a fan of 13x7"s. Does your engineer not require you to have vented discs? Might be easier for you to use the Metro turbo 8.25" setup.
PostPosted: Fri May 15, 2009 4:26 pm
yeah ive been thinking about tyre choice, i know the owner of a bobjane outlet he can get me yokohama's (dont know exact type) for 125 a tyre fitted and aligned. but as for the discs ill have to check with the builder he's been talking with the engineer.
PostPosted: Fri May 29, 2009 7:55 pm
hi all i m doing all the work on the mini . well hope to have in running in the next 3 weeks i m a suzuki gti nut but like all cars if any one needs help with any think suzuki just email me at gtitec@yahoo.com.au
thx
jason
here same of my work
http://www.redlinegti.com/forum/gallery ... um_id=1151
PostPosted: Sun May 31, 2009 9:38 am
I would definatly check out what brakes you are required to run... I think as said vented ones are needed and a dual master system setup is also required??
Life's a garden.... Dig It!
 Post subject: g13b mini
PostPosted: Mon Jun 01, 2009 1:44 pm
yeah we found out that we can squeeze swift gti discs and callipers inside my new wheels :D
http://www.minisport.com.au/prod1504.htm
and we are going to have to work something else out for the duel master system
PostPosted: Mon Jun 01, 2009 2:43 pm
Nice Wheels. 8)
2008 Prado GXL
PostPosted: Mon Jun 01, 2009 6:28 pm
Will be a mean looking mini.
 Post subject: brakes
PostPosted: Wed Jun 10, 2009 6:36 pm
i have just strated fitting all the brakes sys from a suzuki GTI swift 1997
250mmfront and 230mm rear dics. brake booster fitted now
thx
jason
PostPosted: Wed Jun 10, 2009 8:16 pm
Wow that's quite a unique way of mounting the brake booster :shock:
I take it you're not using the standard Mini heater matrix becaue you've blocked off the holoes in the bulkhead for the hoses. Erm - and what about the clutch master?
-Alan
 Post subject: heater and clutch
PostPosted: Wed Jun 10, 2009 8:32 pm
the clutch well be cable only place i could fit it run the heater hoses same where maybe the fire wall .
thx
jason
PostPosted: Wed Jun 10, 2009 8:37 pm
I like that idea for the brake master...
Looks complicated though...
 Post subject: brake setup
PostPosted: Wed Jun 10, 2009 8:44 pm
i made one if it pass ADR ok can make it more if any one wants a big brake seup for a mini no probs
thx
jason
 Post subject: Front dics and wheel
PostPosted: Wed Jun 10, 2009 8:53 pm
Front dics and wheel 250mm rotor and 13 x 7 wheel
http://www.redlinegti.com/forum/gallery ... e_id=13591
PostPosted: Wed Jun 10, 2009 9:27 pm
dammit!.. you beat me to it.. :P I had the exact same idea.. got all the bits including a swift booster!.. but got too lazy and just went for the track test without it.. brakes locked up fine so I decided not to do it..
Originally I wanted to use a clutch mater and a slave and mount the slave so it will actuate the booster from the back. This way I can mount it ANYWHERE I want, but the engineer told me the pedal HAS to have a direct mechanical link to the brake master otherwise it defeats the purpose of having 'dual' circuit system.
good job though.. looks very neat and tidy
