4efte auto https://www.ausmini.com/forums/viewtopic.php?f=23&t=78543 |
Author: | peter dunn [ Wed Sep 19, 2012 9:38 pm ] |
Post subject: | 4efte auto |
can anyone tell me if the 4efte auto will fit in a round nose mini,or is the trans to big. mini regards peter d. |
Author: | JC [ Wed Sep 19, 2012 9:45 pm ] |
Nope, won't fit. Roundnose or clubman matters not. if you could figure out a way where the passenger side suspension tower and lower arm didn't need to be there you might be able to make it work... |
Author: | peter dunn [ Wed Sep 19, 2012 9:57 pm ] |
JC wrote: Nope, won't fit.
Roundnose or clubman matters not. if you could figure out a way where the passenger side suspension tower and lower arm didn't need to be there you might be able to make it work... thanks for the reply. mini regards peter d. |
Author: | JC [ Wed Sep 19, 2012 10:19 pm ] |
![]() It's the big lump on the high right side of this photos that's the problem. |
Author: | Kennomini [ Thu Sep 20, 2012 10:20 pm ] |
Simple, mount the engine and box North-South and line the drive shafts up in the center tunnel and have a diff in the front and the rear. 160-200bhp ATW and AWD ![]() |
Author: | meeni [ Thu Sep 20, 2012 10:51 pm ] |
But auto................. (•_• ) |
Author: | JC [ Fri Sep 21, 2012 7:40 am ] |
Simple. Do keep us up to date with what you find out though Peter. I was always found of an auto converted mini. Actually Peter if you eyeball one and can offer it up to a mini frame I wonder if you could cut away the tower, maintain the mount point on of the top arm and just run some coilovers in the front. |
Author: | Archangel007 [ Fri Sep 21, 2012 11:13 am ] |
Kennomini wrote: Simple, mount the engine and box North-South and line the drive shafts up in the center tunnel and have a diff in the front and the rear. 160-200bhp ATW and AWD
![]() And where would you get 1:1 ratio diffs from??? |
Author: | JC [ Fri Sep 21, 2012 11:20 am ] |
Archangel007 wrote: Kennomini wrote: Simple, mount the engine and box North-South and line the drive shafts up in the center tunnel and have a diff in the front and the rear. 160-200bhp ATW and AWD ![]() And where would you get 1:1 ratio diffs from??? That's the only flaw you can find in that sentence? ![]() |
Author: | peter dunn [ Fri Sep 21, 2012 12:01 pm ] |
JC wrote: Simple.
Do keep us up to date with what you find out though Peter. I was always found of an auto converted mini. Actually Peter if you eyeball one and can offer it up to a mini frame I wonder if you could cut away the tower, maintain the mount point on of the top arm and just run some coilovers in the front. not sure if u could tilt the motor forward a bit ? and who knows unless we try. |
Author: | meeni [ Fri Sep 21, 2012 12:20 pm ] |
Just build new suspension pickups for it, could very simply make an a arm setup that mounts elsewhere |
Author: | JC [ Fri Sep 21, 2012 3:28 pm ] |
I reckon look for a more compact auto. |
Author: | Archangel007 [ Fri Sep 21, 2012 3:42 pm ] |
JC wrote: Archangel007 wrote: Kennomini wrote: Simple, mount the engine and box North-South and line the drive shafts up in the center tunnel and have a diff in the front and the rear. 160-200bhp ATW and AWD ![]() And where would you get 1:1 ratio diffs from??? That's the only flaw you can find in that sentence? ![]() Nope, but the most obvious!! ![]() |
