It is currently Mon Jul 07, 2025 11:18 pm
 Post subject: Driveshafts
PostPosted: Wed Sep 14, 2005 8:48 am
Well finally got the driveshafts back. I am pretty happy with their work even if I wasn't overjoyed at the price tag but by all accounts it was ballpark. So these should go in on the weekend. I have also started on the alternator mount, which hopefully should also be done this wkend.
PostPosted: Thu Sep 15, 2005 6:19 pm
are they completely new shafts?
PostPosted: Thu Sep 15, 2005 6:34 pm
No mano they are the old Starlet driveshafts. They simply turned the fat one down to match the Mini driveshaft diameter and then put splines on both the shafts after having measured and cut them to length. The thinner starlet shaft (in the middle) is almost the same diameter as the Mini item so did not require turning down.
PostPosted: Thu Sep 15, 2005 6:39 pm
ok cheers
does any one think that I could make a living putting efi motors in mini's?
I am keen...
PostPosted: Thu Sep 15, 2005 8:45 pm
manofaus wrote:
ok cheers
I am keen...
I'm happy to provide finance
PostPosted: Thu Sep 15, 2005 8:55 pm
Bloody oath.
But what's wrong with A+ EFI? :lol:
PostPosted: Thu Sep 15, 2005 9:11 pm
Nice work mate shouldnt be 2 far away from the road :D
Blackrz
(998cc Clubman)
- = :Zone 3 Goober: = -
http://photobucket.com/albums/y142/blackrz/?sc=1
"I Live My Life A Quater Mile At A Time"
PostPosted: Thu Sep 15, 2005 9:50 pm
big willy wrote:
Bloody oath.
They don't friggin' GO?? :lol:
Get more HP with carbs.... very popular conversion overseas!
PostPosted: Fri Sep 16, 2005 1:55 pm
Yeah Black the driveshafts are one of the big ticket items, with the engine in and the shafts in place you are almost there the rest is nuisance staff like loom, alternator etc. Spot welded the alternator bracket last night so come the end the of the weekend that should be mounted!
Now I just have to sort out the intercooler which is proving to be the trickiest part...
 Post subject: Belt
PostPosted: Fri Sep 16, 2005 6:13 pm
Matt..do you have the original alternator belt tensioning device/adjustment somehow included.... :?:
From your description of those driveshafts they should be quite stong...stronger than the originals maybe (less lever length)....
PostPosted: Fri Sep 16, 2005 7:08 pm
Is the bottom one in that pic the old mini?
How good an idea is it to simply turn down the toyota shafts! Assuming of course they weren't on their way out. Sounds much easier than mating the two up. How much wasit Matt?
PostPosted: Sat Sep 17, 2005 8:48 am
Bungholio, they cost $550 all up. They had a fixed price on splining which was $198 so they only charged me and extra hundred to measure them and turn them down (the other $50 came from GS effing T). More than I thought but still a good price. And yes the one at the bottom is the old mini driveshaft. As for strength I don't think I will snap these in a very long time...
As for the alternator the standard adjustment bracket will be used similar to the one used on the mini item. No belt tensioner on the Starlet. Once it is done and installed I think you will get the picture... :wink:
PostPosted: Mon Sep 19, 2005 11:14 am
did they heat treat the splines? thats one of the major probs with doing the job here in WA.. most people dont heat treat afterwards.. which makes you rip all the teeth off under high load
Expert in training
PostPosted: Mon Sep 19, 2005 12:35 pm
Weakest part of any Mini driveshaft is the inner (2nd from end) circlip groove, at the CV end. Competition S ones in UK had a stop ring welded on there instead, to avoid notching into the splines.....
PostPosted: Mon Sep 19, 2005 1:19 pm
I have always been told that heat treating is only necessary if you have previously had to heat the steel to work it. I am pretty sure these guys did not heat my driveshafts to put the splines on. And given that the driveshafts would have previously been tempered this is not necessary. MiniVan the full process of professionally heat treating (annealing, hardening and tempering) is quite an involved process requiring a specialised furnace if you want to really do it properly, which is why alot people don't do it.
