Rotary mini: Can it be done? Stay tuned!
https://www.ausmini.com/forums/viewtopic.php?f=23&t=9053
Page 1 of 4
Author:  SnoBall [ Wed Jul 13, 2005 9:45 pm ]
Post subject:  Rotary mini: Can it be done? Stay tuned!
Hi guy's, ever since I bought snoball I keep looking at the RX7 and wondering if the all-mighty Rotary can breath life into my morrie, and would wish it so.
I am putting out a request for help on finding information that can help me on achieving my mission of Rotorizing a mini. Anything would be greatly appreciated; all information will be looked into.
Wish me luck!!!!!! :wink:
Author:  marcsvenson [ Wed Jul 13, 2005 10:03 pm ]
mate i wish you luck as i can say it will not be easy
i have seen one or two attempts and they needed a large tunnell through the car its the torque you cant use a mini box
no way rx7 engine need a small one
Author:  spathi [ Wed Jul 13, 2005 10:05 pm ]
its been done here on the sunshine coast, QLD. company called 'rotormax' has done this conversion several times.
they use a mitsubishi cordia gearbox. I dont have much more info then that. im sure you could find rotormax in the white pages though.
Last time I talked to Doug at rotormax the conversion cost about 7 grand drive in drive out. that may have been with a supercharger as well though, can't remember, it was a couple of years ago.
Author:  marcsvenson [ Wed Jul 13, 2005 10:15 pm ]
the same engine thats in an rx7 or a smaller one???
Author:  benjamin [ Wed Jul 13, 2005 10:33 pm ]
probally a 12a for front wheel drive use
Author:  drmini in aust [ Wed Jul 13, 2005 10:57 pm ]
I've heard they just used a single rotor. Probably 13B.
Author:  SnoBall [ Wed Jul 13, 2005 11:20 pm ]
Sorry man, but mazda only ever made single rotarys in concept form.
10A,12A,13B are all twin rotors! 8)
Yea, i recon i'll drop a stock 12A 4/6 port with EFi, *MAYBE* an Extend port, anymore would be stupid!!!
Fwd is th go, Rwd would be waaaaaay too expensive!! :wink:
Author:  Gareth_1330 [ Wed Jul 13, 2005 11:20 pm ]
I spoke to Rotormax a while ago, the fella's name is Doug. nice guy...
As has been mentioned in other forums, he used a nice new 13b, minus one rotor, which i think makes it some kind of 10a *shrugs*.. He used some VW adaptor plate to mate the motor to a cordia box, although i have no idea what kind of VW, im fairly sure its not a stock car, there special plates for some competition engine swap application i think.... And i think the carb (downdraught webber) fouls the bonnet in the conversion, making a scoop neccecary, like the one on my ugly machine heh... He said the exhaust was just a single pipe!... he also said they are quick, with 14,000 rpm on the cars, although i dont know how reliably, how long... but they are running in a mild state of tune... Torque is also a concern... my 1330 pull hard from down low... i dont want to lost that, and im not game to fork 8k to find out i have!
G
Author:  minimechanic [ Thu Jul 14, 2005 7:10 pm ]
damn that would be sick i'd need delaxatives so i would stop myself shittin myself
the only bad thing is u could only drive it on the dragway as you wouldn't be able to engineer it
Author:  SnoBall [ Thu Jul 14, 2005 7:52 pm ]
i guess doug would be setting the motor up North/South if he was using a VW box/transaxle, hence the loss of one rotor. But id be doing it East/West. And as for engineering it, i think it could be done. The only issue is what gearbox, and what subframe work would be carried out.
Author:  benjamin [ Thu Jul 14, 2005 11:04 pm ]
you would be best of modifying a standard subframe, as for what gearbox look for a relivly short fwd gearbox and get a custom plate made up to match it to the rotary
Author:  drmini in aust [ Fri Jul 15, 2005 7:42 am ]
If he used a Cordia box it's mounted east/west. As for the `VW adaptor plate' it's probably the one that's used to adapt other motors onto VW boxes- as is/was common in open wheeler race cars & hillclimb specials. :wink:
Why only use 1/2 a 13B? Maybe it's to get under the cc limit for a road Mini...???
Author:  cazmo [ Fri Jul 15, 2005 10:52 am ]
does anyone know what the cc limit for a road going mini is?
Author:  13secmini [ Fri Jul 15, 2005 4:16 pm ]
in NSW it is 3x the body weight NA,,,,, 2.5x the body weight turbo
So to put a 12a in a mini it must weight in at 800kg as i think they class a 12a at 2400cc
Author:  Gilly [ Fri Jul 15, 2005 10:47 pm ]
Is it really worth the effort?
6 port 12a around 80kw and lacks tourque, drinks fuel like a family six cylinder and unreliable
You can get a better result and save money sticking with the A-series,G13b, Starlet turbo etc.
Believe me Ive owned a couple of rotaries before turbo and bridge-ported they are a headache and technology with conventional engines has caught up and surpassed the efficiency of a street rotary.
Page 1 of 4 All times are UTC + 10 hours
