It is currently Wed Jul 23, 2025 8:41 am
PostPosted: Sun Sep 27, 2009 5:00 pm
Bit more progress :lol:
Is that the same type of chassis (semi monocoque according to Chris B) as yours Jon ?
PostPosted: Sun Sep 27, 2009 6:29 pm
yes it is the same and i had it up to 135 kph last sunday. It was fun.
Going to a sprint race in two Sundays time to give it a bit of track time.
Hey Ian if it's possible could I get 3 bodies of you ? { all costs will returned }
The pics and messurements are coming I have been a bit slack sorry.
PostPosted: Fri Nov 19, 2010 3:06 pm
Hows the model going? finished yet
PostPosted: Mon Dec 06, 2010 7:40 am
NO sadly , I've been having multiple failures doing the bodywork . I have tried heating and shaping styrene card and also thin aluminium but it just doesn't hold it's shape enough to look realistic . I have made a body block from balsa and am using that to shape the plastic and aluminium over , trying slightly heavier aluminium sheet now but if that doesn't work might try casting it in fiberglass resin .
PostPosted: Mon Dec 06, 2010 9:29 am
tried copper sheet? need to be careful because it dents so easily, but might work
PostPosted: Mon Dec 06, 2010 9:34 am
Having trouble getting a hold of other metals , no hobby shops here :( Looking for brass sheet as well to try but just haven't found it . Found an old copper boiler at a recycle yard that was pretty dented but they wanted antique prices for it so it stayed there ...
PostPosted: Mon Dec 06, 2010 11:34 am
you tell me what you want and I'll go to my local shop...
the aluminium sheet you've tried - coke can?
PostPosted: Mon Dec 06, 2010 5:59 pm
Try litho plate from model train supplies try this link http://www.rcgroups.com/forums/showpost ... stcount=10
Regards Daren
ps still no project X sightings
PostPosted: Mon Feb 28, 2011 5:32 pm
Progress is happen this again now , got some 0.5mm aluminum sheet from Bunnings that holds the shape well without denting too easily :)
PostPosted: Tue Mar 08, 2011 10:27 pm
Are you building a TS or a TSS?
