It is currently Sat Jun 28, 2025 9:00 pm
PostPosted: Fri Nov 05, 2010 9:03 am
Panthersteve wrote:
Hey Simon
Where is this one from :?:
Steve
one of Matt's links - http://cgi.ebay.com.au/Crossway-Models- ... _530wt_905
PostPosted: Fri Nov 05, 2010 11:10 am
tuff998 wrote:
haha just saw those crossway ones on ebay. but it says that it doesnt have engine detail. maybe find a roundy model and use the engine from that. I want the build it yourself kit models :P
If you go to the crossway page on the web (link in my post earlier) you can buy from them the kit with engine detail.
It will still be 1/43 scale.
There is also the 1:87 scale White metal kit by Springside. Otherwise Ian's suggestion of the Clubman resin front for the fujimi kit (I think it's 1/43 ish) gives you a plastic build your own kit. (IF you can track one down)
I'd suggest the crossway will give you best detail and least amount of fiddling to get right.
No easy answer on these ones though :)
PostPosted: Fri Nov 05, 2010 5:51 pm
It's 1:24th Matt , the same scale supposedly as the Tamiya model but they are slightly different scale so can't be crossed over without a fair bit of extra work :(
