painting mini model
https://www.ausmini.com/forums/viewtopic.php?f=28&t=48877
Author:  Bubbacluby [ Fri Jan 02, 2009 9:03 pm ]
Post subject:  painting mini model
What is peoples opinion of painting a mini model to get a smooth shiny finish??
I was thinking about buying a model airbrush kit thing - there pretty cheap from ebay like $30 - $40.
I have a model im goin to make look like mine :lol: :lol:
Its a dinky
Cheers brenton
Author:  Boyracer [ Fri Jan 02, 2009 10:19 pm ]
You can do the air brush thing or you can buy a little aerosol cannister from your local automotive paint supplier followed by a clear coat if you're using a metallic. That's what I did.
I'd bought a cast alloy model, dismantled it. Paint stripped the body and resprayed it with the same colour as my car. The paint guys actually mixed the paint up for me from the colour code I gave them. It was probably the smallest sale they ever made. LOL
Author:  Caponix [ Fri Jan 02, 2009 11:38 pm ]
one thing you have to be careful of with some automotive paints used on models is that they are made differently to model paints, and in some cases can 'eat' the model :shock:
Author:  Flute [ Fri Jan 02, 2009 11:44 pm ]
Sports 850 has done some, no doubt he will help when he reads this.
Author:  sports850 [ Sat Jan 03, 2009 6:47 am ]
What is the model , I'm guessing ou've got a corgi clubman you are going to paint up the same as your GT will be ? If it's a die cast metal model then automotive paint will be fine , use an aerosol can of primer , rub it back with very fine wet and dry paper then paint with an aerosol can , an air brush or even a normal automotive spraygun (on a fine mist , don't spray it as heavy as you would a car) . I used automotive touch up paint aerosols on the two monet carlo mini's I did a while ago in here somewhere .
If it's a plastic kit however automotive paints and the thinners used in them will most likely dissolve the plastic and you'll be left with a bubbly abstract impession of a mini sculpture . Model paints from any hobby store are best for plastic , they can be thinned following the manufacturers instructios and sprayed with a cheap air brush or similar (normally there isn't enough in a tin/jar to put through a normal spray gun) .
Author:  sports850 [ Sat Jan 03, 2009 7:30 am ]
Have a look at this Brenton , http://www.ausmini.com/forums/viewtopic.php?t=39508
Just remember though that what I did there won't work with plastic models as the auto thinners eats them .
Author:  Boyracer [ Sat Jan 03, 2009 7:30 am ]
Actually, wasn't there a thread showing some truly amazing work someone had done with models?
It was about a year ago, iirc.
Author:  Bubbacluby [ Sat Jan 03, 2009 10:11 am ]
Thanks for the reply...
Yeah its a metallic gold dinky mini clubman thats been trashed i bought from ebay
Dinky No.178
Thanks for the link Ian, basically sums up what i want to do
Thank for the help everyone
Brenton
Author:  sports850 [ Sat Jan 03, 2009 12:12 pm ]
There is also this thread of Miguels on the IMMCC which show's a modified 1275 GT , you could do similar to yours and add external door hinges and use a texta to put 1/4 vents in the windows ...
http://excoboard.com/exco/thread.php?fo ... did=424209
Author:  Bubbacluby [ Mon Jan 05, 2009 10:07 pm ]
Wow thats pretty indepth and full on.. that link should be very helpful though
How would it be possible to ad external door hinges??
(This remodel sounds as though it may be more indepth and detailed than first planned :D )
Thanks
Author:  sports850 [ Tue Jan 06, 2009 5:44 am ]
You'd have to glue the doors shut like Miguel has in that link , then cut some tiny slivers of plastic (or even coke can) and glue them on . WIll be fiddly but will really make the difference . They will only have to be tiny too .
Author:  minifreak1 [ Wed Jan 21, 2009 7:02 pm ]
I resprayed a modle porsche 911 for a freind of mine...it was white but his real one was yellow...i pulled it all apart....took lots of photos of it and resprayed it but baked it in our oven and i got a great finish...nice and smoth...as i heated the car inbetween coats...so paint went on with no runs..
i did my metro brake calipers the same way too...stunk the house ...so wife wasent very happy
