| ausmini https://www.ausmini.com/forums/ |
| Tamiya M-05 Mini - Steering issue https://www.ausmini.com/forums/viewtopic.php?f=28&t=84363 |
| Author: | ByteSize [ Wed Jan 29, 2014 8:44 pm ] |
| Post subject: | Tamiya M-05 Mini - Steering issue |
Hi all I have just picked up an M-05 Mini kit and have it all assembled. The only problem I have is that the servo has a nice turn which causes the steering to loose connection between the drive shaft and the front axle which causes the steering to jam. The drive shaft stays in the gear box joint but slips out of the front axle groove. I'm planning on racing it so I didn't want to fit anything that wasn't "race legal". This would solve my problem but I'm not sure if it is within the rules of the car clubs... http://www.redrc.net/wp-content/uploads/2011/07/YeahRacingM05DriveShafts.jpg Does anyone have any experience with the M-05 chassis or steering that might be able to offer some ideas? -Andrew |
| Author: | ByteSize [ Fri Jan 31, 2014 8:51 pm ] |
| Post subject: | Re: Tamiya M-05 Mini - Steering issue |
Thanks Peter for the info. I have the O-ring on the inner cup but not in the outer cup. The servo is perfectly aligned and has an auto self centering mechanism and turns each direction evenly. Just on the hard lock (with the wheels spinning), the driveshaft just seems a fraction short to stay in the main outer axle cup. I think Ill invest in the universal shaft arrangement. They don't cost much and I think it will solve my problem. They seem like a nice size chassis to race with. |
| Author: | Harley [ Mon Mar 17, 2014 8:32 am ] |
Servos are over travelling past what the car was designed to have. If your radio has an endpoint adjustment use that, otherwise see if you can move the ball ends on the ervo closer to centre, or the ones on the arms further away from the pivot. |
| Author: | Brik Nuts [ Mon Mar 24, 2014 4:13 pm ] |
Sweet Peter you have a wild willy......is that first generation? Looks like you are restoring it? I got mine as i kid and it got a bit bashed up....a kid I let drive ran it into a wall and smashed the grill and bent the front springs. is the mini and that thr only 2 rcs you hav? cant help with the mo5 mini sorry. Cheers |
| Author: | LeylandMiniPhil98 [ Mon Apr 07, 2014 2:01 pm ] |
i Have a hobao Hyper 7, HPI 5SC, one M05 mini(monte carlo like yours)however mine won't be painted like that, i just wanted the spotties and some of the transfers. i also have a small plane and an HPI Blitz. i'm more into offroad, that's why i will be taking the suspension out of a 1/10 short course truck or buggy and swapping the stock shocks in the mini for them. Reseal all of the plastic parts and a few other things to make it more durable. Has anyone had problems with the tires rubbing on the front arches? I have and if i extend the wheelbase, it won't make a difference and i don't want to trim the arches too much otherwise i lose them and i want to keep the superwide arches. |
| Author: | peterb [ Mon Apr 07, 2014 8:14 pm ] |
Yeah, they do rub, a few fast runs usually takes care of that. So you basicly making a rally mini? |
| Author: | LeylandMiniPhil98 [ Mon Apr 07, 2014 11:33 pm ] |
I want to have a rally kit for it so to speak. I want to be able to change it back to track monster aswell. Basically, it will project what my mini will eventually look like, excluding the fact that mine will be a clubman. |
| Author: | LeylandMiniPhil98 [ Mon Apr 07, 2014 11:34 pm ] |
I am going with the solution of rubber spray or gaffer tape under the arches so as not to rub the paint off. That brushless power of mine is enough to do burnouts too! |
| Author: | LeylandMiniPhil98 [ Mon Apr 07, 2014 11:36 pm ] |
Its a problem with a few short course trucks when they land big jumps so for extra protection, people just spray a coat or two of rubber on the inside. Adds weight but also acts as a buffer so the body doesn't rattle around of you get what i mean |
| Page 1 of 1 | All times are UTC + 10 hours |
| Powered by phpBB® Forum Software © phpBB Group http://www.phpbb.com/ |
