It is currently Fri Jul 11, 2025 6:44 pm
PostPosted: Wed Sep 13, 2023 8:21 pm
I have a stock standard 850 and am looking towards changing out to a newer 998 or 1100. Is there any worthwhile mods that can be done without major engine work to gain some extra horses on a standard 850?
PostPosted: Sun Nov 05, 2023 11:22 am
Find a big hill and go down instead of up?
PostPosted: Sun Nov 05, 2023 4:13 pm
Most mods which are applicable to bigger engines will work on an 850 to some degree.
David Vizard's books have good ideas.
Cheers Dave.
PostPosted: Tue Nov 07, 2023 9:25 am
Maybe you can get the kids to push? :lol:
PostPosted: Tue Nov 07, 2023 10:45 am
I have an 850 with a 202 head, but never got to test it out much because the primary leaked oil into the clutch and killed it. I've since moved on to 1098s.
I wouldn't bother, make sure it is all perfectly tuned as stock and enjoy the period experience.
PostPosted: Thu Dec 14, 2023 9:19 pm
Fit a 998 cc crank
PostPosted: Sat Dec 16, 2023 8:28 am
i got a mini wrote:
Fit a 998 cc crank
Won't fit without machining either the block, or the crank webs. Main bearings are wider on an 850.
Back in the 60s I fitted several 1098 cranks and pistons into 850 blocks. Slight mods to the conrods.
Put a 998 or 1098 motor (more torque) into it. :mrgreen:
