It is currently Wed Jul 16, 2025 12:25 pm
 Post subject: LCB - question
PostPosted: Fri Aug 06, 2004 2:59 pm
Are the exhaust ports and manifold attachment points universal across the a-series range of engines?
I have my eye on getting a Maniflow LCB for the recon 1275 [still yet to be obtained], but the existing 1098 exhaust is rappidly reaching it's used by date. I need to do something about it or stop driving the van for a while :cry:
Please tell me they fit all engine sizes so I can pick one up at Minishow04
PostPosted: Fri Aug 06, 2004 3:37 pm
whilst I'm not an expert, from the literature I've seen the answer to your question is yes.
All the mini heads are the same in this respect. Can't speak for sprites and other possible engine combos. The 1275 is slightly taller than the smaller capacity units as I understand, but that shouldn't stop a set of extractors from being swapped from an 1100 to a 1275 or vice versa for example.
Certainly some of the spares catalogues I have list the one set suiting many engine capacities.
KB
PostPosted: Fri Aug 06, 2004 5:29 pm
yeh they bolt straight on ;) the lcb on my 998 in the pics is a 1275 one , :D
lookin for another clubby
PostPosted: Fri Aug 06, 2004 6:09 pm
excellent - thought so
Thanks guys
PostPosted: Fri Aug 06, 2004 7:14 pm
All A series heads, from the humble 803cc Minor & A30, to the mighty 1275 Cooper S have the same manifold stud spacing.
A Maniflow medium bore LCB will be fine on your 1098. be aware they hang pretty low though- more than most do. Watch out for speed humps in shopping centres... :cry:
I replaced the main pipe exhaust clamp with a strap type one I made, similar to the 2 smaller ones on the branch pipes.
PostPosted: Fri Aug 06, 2004 7:23 pm
Hugh, how are you getting to the Mini Show?
PostPosted: Fri Aug 06, 2004 8:20 pm
Driving over at sparrow fart in the Telstar on the Sat morning
PostPosted: Fri Aug 06, 2004 8:31 pm
Mini show! What mini show??????
PostPosted: Fri Aug 06, 2004 8:35 pm
Melbourne is it? A huge mini event.
I wish i was going :cry:
rovermini... what do you drive? Got pics
PostPosted: Fri Aug 06, 2004 8:56 pm
Toyota Surf 4x4 at the moment. I'm in the process of getting an import Rover Mini though.
Shame I'm in Adelaide or I'd be heading to the show
PostPosted: Fri Aug 06, 2004 9:31 pm
Quite a few of us from SA are going over Rove
Check it out at http://www.mini.org.au/minishow2004/vmci2.htm
PostPosted: Mon Aug 09, 2004 11:46 am
hey rove,
where ya getting the rover from?
not 875-874 south Rd edwardstown *brickworx racing* are ya?
looooooooots of NICE rovers,they is cumming in all the time,cheap 2 :D
