It is currently Fri Jul 18, 2025 11:53 am
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Sat Aug 14, 2004 9:35 pm
Before you get too excited, a Swift GTI motor with twin Webers instead of injection gives more power. Ditto the Vauxhall 2.0L motor.. :wink:
yeah but properly set up injection will always give greater flexibility. Not as important on an all or nothing race car....
PostPosted: Sat Aug 14, 2004 10:08 pm
This GTI was in a Clubman sports car with Alfa 105 box. He got well over 150HP on twin Webers, no turbo.
OK yeah, it is a race car. :lol:
PostPosted: Sun Aug 15, 2004 1:17 am
Maybe so, but try remapping the EFI when you change the cam....
I wanna rip off the EFI on my Mazda simply because i cant do bolt ons without having to remap it.... REALLY sux
 Post subject: EFi
PostPosted: Fri Aug 27, 2004 5:04 pm
If I get a chance when at home. I'll post some pics of the EFI system I fitted to my mini years ago :)
Based on the 4cyl Camira EFI system, using it's throttle body, two injectors, Civic Hall effect dizzy, Custom inlet manifold etc.. with a programmable delco '1227808 ecu... ran very nicely :)
It isn't hard, I could only find one or two people who had dealt with thier own systems from scratch back then, but I was very happy with only having to turn the key when I wanted to start it, and having it purr away :)
PostPosted: Fri Aug 27, 2004 5:52 pm
Yeah but if you are going to set up a carb engine properly, including dialling in the cam, dizzy and the jetting, you need just as much time on the dyno, and someone who equally knows what they are doing. If you add any bolt ons that affect any of these things then a trip to the dyno for setup is just as necessary for a carby car as it is for EFI. You can just as easily run a carby too lean.
Remapping the EFI software on a standard computer is a pain i will admit, but if you spend the money on a good carb system, it costs about the same or more than an aftermarket EFI computer. The number of dyno operators who can properly jet a carby is shrinking.
One last thing, if you think dyno time is a waste of money, it all depends on what you spent on the engine in the first place.
My brothers sports sedan has an Autronic computer, and i would recommend it to anyone over the MoTec that was in it for ease of set up and operation.
My 2c
