It is currently Mon Jul 21, 2025 6:57 pm
 Post subject: Help needed with Diff
PostPosted: Sat Feb 11, 2006 10:04 am
Hi everyone I need some help im trying to dismantle the Diff off a Rod Change type Gearbox my first problem is removing the Drive Joints the Manual says I need Special Tool 18G 1240 does anyone know what it looks like or where I can get one or is there a way of removing them.
My next question is will the interals out of a remote style Gearbox fit into the Rod Change Diff housing as I need to use the drive couplings off the remote Gearbox but prefer the Rod Change gear selector
Thanks for any help Cheers wayne
PostPosted: Sat Feb 11, 2006 10:47 am
I'm assuming you mean the pot type inner CV joints ? These are hld in by a wire circlip held between a groove in the diff shaft and a groove inside the CV joint . The tool in question is something like a slide hammer with metal fingers to fit between the diff housing and CV joint . A short , sharp pull is normally enough to split them , at times putting a big screwdriver in between and giving it a "flick" can be enoungh . You just need a little bit of a snap movement to get the circlip to slip into the diff shaft a little more and the CV will slide off . Just try to get it to pull straight , hence the slide hammer with fingers ....
PostPosted: Sat Feb 11, 2006 3:57 pm
I use a tool looks like a wide cold chisel with a 32mm slot cut in it.
Today I needed it and didn't have the tool here, so I bumped them off with a club hammer and `big drift' (a stuffed layshaft).
Box out of car, they came off easy.
PostPosted: Sat Feb 11, 2006 8:26 pm
Big chizzzle Or drift & FBH
& yes
PostPosted: Mon Feb 13, 2006 5:06 am
Pukka tool looks like a boot/shoe remover (flat plate witha wide slot in it) and a block on the back. Whack it in with a mallet and the pot joint pops off. Failing that, a coule of tyre levers 'crossed' and down behind the joint with a sharp 'shove' should do it. If it doesn't work after a couple of attempts - turn the joint 1/4 turn and try again. It's sometimes down to where the circlip open end is hanging. KC.
Tuning should always be a compromise between what is possible and what is necessary.
www.calverst.com
