& then 160thou oversize (74.7mm) makes 1426cc ,,, then add an 84mm stroker crank & you have 1485cc,,, or add an 86mm oversize crank & you end up with 1510(ish)
all the stroker cranks that are made from std large journal cranks can vary in stroke length from one grinder to another, some don`t quite end up with the "exactly" the above figures, you may end up with a 1410cc or a 1412 or a 1415 with 73mm bore & 84mm crank,,, you might end up with a 1483cc or a 1485 or a 1486 with a 74.7mm bore & 84mm stroke crank, & then you can get a 1508 or a 1510 or a 1512 depending on what crank you started with & also depending on how it was ground & trued after the whole process
but hey... who`s going to quivell about a couple of ccs here & there???
But still 74,7mm (160thou) oversize is about as far as anyone would want to go,,, there is actually room for more if you`re prepared to offset bore,,, then sleeve it,,, & then offset bore the sleeves to achieve an even bigger engine---> BUT i would highly recomend "NOT" doing so,,, unless you just want a talking piece for the pub counter meal or you`re rich as (or maybe just as stupid as me)
& if you have even more money than sense, you can order a 91mm stroke crank & make your engine even bigger again
if you`re nutso, we have one here, in a mini & ready to fire up & hear it running if you`re keen
