The difference in block height is the stroke difference /2
ie the crank throw difference.
I make it 6.53mm. (81.33-68.26)/2
This assumes standard 1275/1071 Cooper S rods and pistons.
It was the 970S that had a 1/8" longer rod.
So standard S pistons are OK? will be going flat top to bring the compression up.
Excellent, and thanks for the calculations. With a deck thickness of 625thou (5/8") as opposed to 450thou(1100s) the S block is definately the one to find for the job!! Besides I have a cooper s head AEG163, cooper s rods, and the 1071 cooper s EN40B crank, a genuine S block just feels right!
Matt
Thanks Guys
