It is currently Mon Jul 21, 2025 1:53 pm
PostPosted: Thu May 12, 2005 11:43 am
Problem can't remove the actual windscreent wiper bar, can I take the cable out of the motor so that I can give it the once over. Had a look the other day looked a little complex. Any ideas. I suppose I could drill the nuts holding the actuating shafts... :twisted:
PostPosted: Thu May 12, 2005 2:26 pm
http://www.ausmini.com/forums/viewtopic.php?t=4917&highlight=wiper+motor
PostPosted: Thu Jun 23, 2005 4:41 pm
When you unbolt the motor from the firewall, can the cable coming out the top (going to the wiper blades) be removed? Or do the wiper blades have to be taken off aswell?
PostPosted: Thu Jun 23, 2005 10:43 pm
honk you can disassemble the motor mechanism and remove the cable and subsequently the motor mechanism. Or you can under the nuts that secure the stalks under the wipes and the beam underneath should fall away. This is easier than disassembling the motor mechanism.
PostPosted: Mon Apr 07, 2008 7:30 pm
how do you disassemble the actuall motor? im up to the point where the motor is loose and i have undone the cover and can see the gears and cable.. what now? how can i get the cable out, i dont really want to pull all the wipers out either
cheers dion
Mearcat wrote:
PostPosted: Mon Apr 07, 2008 8:29 pm
There is a nut (knurlled?) holding the tube containing the cable to the motor -undo that. Then undo the screws holding the cover on and take it off - under neath you will see a wheel with a pin near the edge and hooked over that pin is a bar that has the cable attached to it - just lift that bar off the pin and you should be able to lift the motor out.
David L
PostPosted: Tue Apr 08, 2008 11:57 am
wiked thanks.
Mearcat wrote:
PostPosted: Tue Apr 08, 2008 7:00 pm
That bar thing that David (wombat) is talking about will have a small circlip retaining it, rip that off & job done
:-) easy-peasy
PostPosted: Wed Apr 16, 2008 8:31 pm
i cant get mine out (the bar) i got the nut and rubber of the passenger side wiper but cant get the drivers side.. the nuts seized..... should be fun !
Mearcat wrote:
