It is currently Mon Jul 21, 2025 1:49 pm
Post new topic Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
PostPosted: Mon May 19, 2008 8:58 pm
69elf wrote:
Dr Mini, That Centre main strap looks great. I always wondered why, when the idea is to add strength to the centre cap, you have to mill some off to add a strap.
Any chance of you running off a few to sell to us more technically challenged?
It's not quite that easy- you first need to surface grind the cap just enough to clean the top up flat, then make the strap and mill a slot in it, and finally surface grind it to give about .0005"-.001" preload when fitted.
So they are a 1 off proposition to make.
:wink:
